diyAudio Sponsor
Old 4th December 2007, 01:35 AM   #1
dsavitsk's Avatar
Question Adjustable Fixed Grid Bias
I am looking for a way to use fixed battery bias on a grid, but to make it adjustable via a pot of some sort. Seems like it should be simple enough to do, but I have to say I'm stumped. Any suggestions?
http://www.ecpaudio.com
Old 4th December 2007, 01:42 AM   #2
You can put the pot. across the battery as an adjustable voltage divider, just as is done with a rectified supply. The problem is that the battery will go dead.
Eli D.
Old 4th December 2007, 03:13 AM   #3
Miles Prower's Avatar
Mixed cathode and battery bias. Put the pot in the cathode lead.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 4th December 2007, 03:35 AM   #4
astouffer's Avatar
You could wire a high value pot in series with the battery (probably a few meg ohms) or use a low noise regulator. The only drawback is they tend to come in microscopic packages, like a .040" square
http://www.national.com/pf/LP/LP5900.html
Old 4th December 2007, 01:39 PM   #5
oshifis is offline oshifis  Hungary
Charge the battery (with a drop charge regulator) when the amplifier is switched off, disconnect the charger when it is on. L200 can be used for this purpose:
http://www.st.com/stonline/products/...re/ds/1318.pdf
Old 4th December 2007, 03:58 PM   #6
kevinkr's Avatar
Hi Doug,
How about variable plate voltage as long as you stay within the allowable dissipation limits this might work well enough and prevent drain on your bias battery with the potential risk for mischief that entails.. I've never tried it so I can't really say how well it would work, but for limited operating point tweaking it should work ok. (Anyone using a plate load ccs with fixed bias is implicitly doing the same thing any time they swap tubes.)
www.kta-hifi.net
Rheostat for adjustable "fixed" bias? porkchop61 Tubes / Valves 11 25th April 2011 08:57 PM
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Finding bias point in PP fixed bias beamnet Tubes / Valves 14 7th December 2008 01:25 PM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Page generated in 0.06965 seconds (76.83% PHP - 23.17% MySQL) with 10 queries
