| diyAudio Sponsor | ||
sorry about my wallet... |
#2 |
What types of valves are those?
7N7
Plug them in and light them up |
#3 |
6DJ8, 6N6Pi and 6V4 rectifier
#4 |
Heater voltage is too low. Those valves should be run at 6.3v
7N7
#5 |
OK... thanks for the advice 7N7. I will try that.
#6 |
7N7, I just re-checked the heater voltage and its 7.5VAC...not 5.7...sorry for the bad data.
#7 |
Aaaarrgghh!
That's even worse! Check your mains supply voltage and the setting on your equipment. You will destroy the valves if you continue. 7N7
#8 |
I would have thought it was an artifact in the camera, as digital cameras have a high IR sensitivity, which shows up as purple in the resulting photo.
#9 | |
7N7
#10 |
In any case, digital cameras will photograph IR as white, not purple. (try taking a photo of the end of your TV remote while pressing the buttons!)
It rather looks as if the valves are gassy, or the cathode coating hasn't been mixed properly/has impurities (such as calcium carbonate, which will give off a blue-ish glow) Looks pretty cool! |
| Switch-mode PSU for tube heaters? | deltavektor | Tubes / Valves | 9 | 31st October 2008 08:07 AM |
| DAC - tube gain stage w/ AC heaters | regal | Tubes / Valves | 5 | 26th August 2008 12:30 PM |
| Tube heaters in series. | nigelwright7557 | Tubes / Valves | 5 | 4th July 2008 09:11 PM |
| Tube heaters AC or DC? | soundbadger | Tubes / Valves | 105 | 1st March 2008 10:04 AM |
| Physically small rectifier tube with 5V heaters | dsavitsk | Tubes / Valves | 7 | 14th June 2006 02:47 AM |
| Page generated in 0.09815 seconds (78.69% PHP - 21.31% MySQL) with 10 queries |
