diyAudio Sponsor
Old 3rd December 2007, 12:27 PM   #1
Default Which 12AU7 and 6V6GTs?
Hey,
Just curious over which brand to buy, this is my first valve amp project, hence the question . I've heard Golden Dragon are a bit iffy, so despite the guy at Tube Shop 's advice....I'll ask you guys.
I'd ideally like to shop there, if possible
L
Old 3rd December 2007, 07:28 PM   #2
Brett's Avatar
Guitar or hifi?
Old 3rd December 2007, 07:56 PM   #3
Hifi, sorry!
L
Old 3rd December 2007, 08:11 PM   #4
Brett's Avatar
Originally posted by Psychobiker
Hifi, sorry!
L
Use something else other than a 12AU7, such as a 6SN7, ECC99, 6H6N.
Sorry it's not the answer you're looking for, but I only ever use them in MI amps, and only to serviceold models.
On a general note though, of the new production Russian tubes, I really don't find that much difference between those I've measured (in cct) beween equivalent types.
6V6's I've used in a guitar amp build recently, but the poweramp side is typical AB hifi design and it went very well with the EH's. So I'd suggest try them or JJ.
Also, don't limit yourself to that store. Plenty of place in the US and for a few tubes, postage won't come to much, esp with current exchange rates.
Old 3rd December 2007, 11:29 PM   #5
diyAudio Moderator Emeritus
ray_moth's Avatar
Agree! They claim "The largest selection of quality tubes online" but I didn't see any 6CG7 or 6FQ7, which are true 9-pin equivalents of the 6SN7 and are much better for audio than the non-linear 12AU7.
Old 3rd December 2007, 11:34 PM   #6
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Default I never miss an opportunity
Yes, I'll second (third actually) that.
12AU7/ECC82? Horrible things.
7N7
Plug them in and light them up
Old 3rd December 2007, 11:37 PM   #7
Many thanks again guys, the 6SN7 looks to be the way forward, not too much fiddlement to be made
L
Old 6th December 2007, 08:55 AM   #8
Just checking, all I really need to do is bring down the Anode voltage to + - 250v, the transconductance is lower than the 12AU7, which apparently is fine. All the rest of the power supply etc remains the same, which is over-engineered for a 6SN7GT, meaning a less stressed PSU
L
Old 6th December 2007, 09:36 AM   #9
316a is offline 316a  England
316a's Avatar
7C5 is a loctal 6V6 , maybe an idea to use these instead as NOS is plentiful and cheap . 7AF7 is a loctal 12AU7 so you may be able to build an all-loctal amp An oddball valve which is very much like a 20w dissipation directly heated 6V6 is the 1624 (glass) or 1619 (metal)
cheers
316A
Old 6th December 2007, 10:42 AM   #10
Yeah, All the same sockets would be handy! Nothing too much in the circuit to change tho? I'm sticking with the 6V6, but changing the preamp tube to a 6SN7 as per recommendation
L
Cycline3 on the 12AU7 Cycline3 Tubes / Valves 24 28th October 2007 04:20 PM
12AU7 instead of 6C4 Dr ZEE Tubes / Valves 9 3rd August 2007 02:25 AM
Question about 12AU7 pho_boi Tubes / Valves 3 3rd October 2005 06:00 AM
How about this 12au7 pre? sith Tubes / Valves 2 13th April 2004 08:27 PM
Wiring a 12au7 A3rd.Zero Tubes / Valves 14 1st April 2004 11:07 PM
Page generated in 0.10018 seconds (78.99% PHP - 21.01% MySQL) with 10 queries
