| diyAudio Sponsor | ||
Hi Folks,
Just read the term 'sleeping sickness'. Obviously relates to tubes with heater current applied but no HV - but what is it? I have performed a search of the forum with little joy. Can you damage tubes by testing the filament circuit during construction? As luck would have it, I was just about to do this with 4 KT88's and 2 NOS mullard rectifier tubes but I will hold off until I get an answer to the above question! Thanks in advance, Rob |
#2 |
No, you won't damage the tube.
Lots of amps have a standby switch to switch off HV and leave the heater volatge applied. This is conroversial, but tubes can withstand quite some time with heaters applied only. Bas |
#3 |
Testing is fine, just don't leave them powered for months...
#4 |
I heard the term "cathode poisoning" that is a reduced emmisson capability when the cathode is heated up, emitting electrones, but they form a cloud around the cathode due to lack of anode voltage. The result is some reversible change in the cathode emission coating. It can be reversed by overheating the cathode for a short time. The cathode poisoning should be a long-term effect, anyway.
#5 |
Yes this is covered in Valve Amplifiers.
The trick is to leave the valves with their heaters at around 63% of full voltage, then there is apparently no problem with "sleeping sickness". This ratio was discovered empirically. 7N7
Plug them in and light them up |
#6 |
Search the terms "cathode stripping" and "cathode baking" for more info. Beware - there's a lot of controversy surrounding both.
For what it's worth, I've got a 6BQ5 amp with solid state rectification. I use a standby switch on it to try and reduce stripping. I try not to leave it on standby too long, to minimize baking. If I were going to test out a new build, I wouldn't worry too much about leaving the heaters running (without B+) for ten or fifteen minutes while I took some voltage readings. I wouldn't make a habit of it, though. |
| Yep, it's a sickness | tsmith1315 | Car Audio | 6 | 10th June 2009 12:45 PM |
| Do I have a sickness? | Jonny Hotnuts | Car Audio | 19 | 17th February 2008 07:18 PM |
| Is welbornelabs sleeping on the job! | RogerWilco | Everything Else | 4 | 23rd November 2005 08:05 PM |
| Bass horn: sleeping on the job | Mr Evil | Multi-Way | 15 | 10th July 2005 08:57 AM |
| Page generated in 0.08622 seconds (80.06% PHP - 19.94% MySQL) with 10 queries |
