diyAudio Sponsor
Old 2nd December 2007, 06:20 AM   #1
Default 50L6-GT or 6W6-GT
I been thinking to built a mono single ended amp and I got a
CBS 6W6-GT and a Mullard 50L6-GT...wich sounds better?????
any good schematic???????????
Old 2nd December 2007, 07:46 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
It's the same tube.
Old 2nd December 2007, 04:10 PM   #3
astouffer's Avatar
No they aren't.
http://www.nj7p.org/Tube4.php?tube=50L6GT
http://www.nj7p.org/Tube4.php?tube=6W6GT
http://webpages.charter.net/dawill/t...its/6W6_PP.gif
Old 2nd December 2007, 04:27 PM   #4
Tom Bavis's Avatar
They're the same tube with different heaters.
But having a certain tube is a poor reason to build an amp around it - tubes are one of the cheapest parts in a tube amp.
Old 2nd December 2007, 06:29 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I use 12L6 tubes (similar to yours) to drive power MOSFETs in hybrid amps. They are decent tubes, and don't require high plate voltages. 170V PS is more than plenty.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 2nd December 2007, 07:51 PM   #6
astouffer's Avatar
50L6:
Maximum Ratings (Design Center Values)
Pentode
Plate Voltage ................................. 200 V
Grid No. 2 Voltage ............................ 117 V
Plate Dissipation ............................. 10 W
Grid No. 2 Dissipation ........................ 1.25 W
6W6:
Pentode
Plate Voltage ................................. 330 V
Grid No. 2 Voltage ............................ 165 V
Plate Dissipation ............................. 12 W
Grid No. 2 Dissipation ........................ 1.35 W
The 6W6 is beefier and gives an extra watt in SE.
Old 2nd December 2007, 09:11 PM   #7
KaDe is offline KaDe  Germany
KaDe's Avatar
Default 6w6gt
For the moment I´m playing the 6W6 in push-pull UL-mode : 250V B+, 30mA each
- sounds very linear and objective to me -
Old 2nd December 2007, 09:22 PM   #8
Default Re: 6w6gt
Have you got the schematic or info about the output transformer???????
thanks to everybody...
my english isn't good...sorry...
Old 3rd December 2007, 12:10 AM   #9
KaDe's Avatar
Default 6W6
Thanks Ivan for your interest on my tube breed-box.
It was not my intension to change your mind from single-ended into push-pull.
It just happend so yesterday that I plugged this 6W6GTs in my 8417 MFE-amp for a listening test and was pretty surprised about their stunning sonic performance with my corner-horn speakers.
They should sound even better single-ended.
Go ahead with a 4 k Ohm load transformer for 3,8 SE-Watts !
Klaus
Page generated in 0.08251 seconds (78.97% PHP - 21.03% MySQL) with 10 queries
