| diyAudio Sponsor | ||
OK, I'm listening away at lowish volume and notice the right channel is a little low, so I ignore it thinking it may be the way Jose Felliciano is recorded, I ain't heard him in a while. I get up to walk out and make a coffee and notice one tube not lit at all and it's the furthest right tube in this pic.
So I swap the two on that channel around and the suspect tube lights up for a few seconds then dies, so it's the tube? Not the socket? I then change the tube to the furthest left on the left channel and it plays fine. When I did this last change, I swapped the speakers back to 4ohm taps from the 8ohm taps. Could this have been the issue? Or is the tube stuffed? It is the only one with brown marks on the top of the tube and discolouration of the metal inside.
#2 |
It could be a loose connection between the tube pin,and the little wire that comes out of the glass.
If you have a soldering iron,try heating the filament pins (or all of them,heck) and maybe apply a bit of solder,if you like. Or,maybe the filament wire is broken/loose inside the tube,if so it's stuffed.
| PSU - dropping resistors? | AndrewF | Tubes / Valves | 4 | 27th February 2008 08:58 AM |
| Router cutter dropping! | dnsey | Multi-Way | 16 | 11th July 2006 01:40 PM |
| Why is my MOSFET dropping so much voltage? | arnoldc | Power Supplies | 19 | 21st April 2006 07:52 AM |
| I feel like dropping the puck, so I will. | KBK | Solid State | 14 | 18th November 2005 07:38 PM |
| Dropping Speakers | NicolasGaal | Multi-Way | 5 | 21st January 2004 10:49 PM |
| Page generated in 0.06182 seconds (70.61% PHP - 29.39% MySQL) with 10 queries |
