diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Active crossover (http://www.diyaudio.com/forums/tubes-valves/112931-active-crossover.html)
ivan-UTN-ARG 2nd December 2007 03:36 AM
Active crossover
hi,
I'm looking for a simple schematic of a 2 way 12dB/oct active
crossover with 12AU7 or 6CG7
the crosover frecuency should be 2khz (aprox).
planet10 2nd December 2007 04:37 AM
http://t-linespeakers.org/tubes/xos.html
dave
soundbrigade 2nd December 2007 09:06 AM
You can download a X-over designer from Elektor Electronics:
Tube-Based Crossover
Gives you a PCB-designer as well.
mashaffer 3rd December 2007 12:39 AM
A related question. It has been a looooooooonnnnnnnnnngg time since linear circuit analysis class. Can anyone explain how to derive the transfer function for that 3rd order LP as shown in the above link? Does one have to model the tube or can you somehow derive the voltage division of the ladder network and then layer on the effect of the feedback capacitor?
I would like to understand this circuit well enough to move poles around and also adapt it to sand (sorry I got lots o sand and low voltage power transformers on hand on no tube stuff yet).
mike
Resources saved on this page: MySQL 18.75%
