diyAudio Sponsor
Old 29th November 2007, 11:50 PM   #1
Fuling is offline Fuling  Sweden
Default 6HB6/6HA& Spud?
Good evening.
Does anyone have triode curves for 6HA6/6HB6?
I have a bunch of them and according to this ( http://frank.yueksel.org/sheets/135/6/6HB6.pdf ) datasheet they might be possible candidates for a spud amp.
Pa 10W + G2 2W (12W as triode?)
Gm is >20mA/V
A possible OP might be somewhere around 200Vp , 50mA and -3V (guesstimated...).
Old 3rd December 2007, 07:24 AM   #2
JLH is offline JLH  United States
JLH's Avatar
The only thing I can tell you is the triode connection results in a Mu of about 27. And in order to get anything near 20mA/V you have to run the crap out of it. A more typical operating point will only yeld a Gm of around 12mA/V - 16mA/V.
Rgs, JLH
Old 3rd December 2007, 07:27 AM   #3
Not worth the trouble, then.
BTW I have already ordered a bunch of 6S45p and a pair of James 6112HS OPTs to build a spud with.
Old 3rd December 2007, 08:06 AM   #4
dsavitsk's Avatar
Originally posted by Fuling
I have already ordered a bunch of 6S45p ... to build a spud with.
Most of us who have played with this tube find that it sounds its best at lowish currents (~10mA or so) which makes it not really great for spuds. I think you'll do better with a 7788, D3a, etc. which do will at higher currents.
http://www.ecpaudio.com
Old 3rd December 2007, 10:22 AM   #5
Others claims the opposite, so I guess I have to find it out myself.
I made a breadboard with triode wired E280Fs a while ago, it sounded great but the output power was too low for it to be useful with my speakers. D3A would probably put out a tiny bit more power but still not enough.
E55L would probably be absolutely wicked but they seem too rare and expensive.
There are a few other weird tubes (some russian microwave stuff amongst others) that has some potential for operating in spud amps, but most of them requires strange sockets and additional input buffers.
If it turns out that the 6S45 spud is not up to my expectations I can always use the parts in other projects.
Spud anyone? tubelab.com Tubes / Valves 88 12th January 2010 01:22 AM
Which Spud Amp? ambience exists Tubes / Valves 0 23rd July 2008 10:43 PM
Is this a Spud Amp ? mod_sonic Tubes / Valves 7 12th July 2006 12:11 PM
Page generated in 0.07295 seconds (76.15% PHP - 23.85% MySQL) with 10 queries
