diyAudio Sponsor
Old 28th November 2007, 10:40 PM   #1
Default Electro Harmonix 300b...shorting problems?
Greetings, I'm running a pair of Dared VP-300b mono's. One tube will draw 130v through the 1K cathoded resistor. This happens about every 4th start up. The problem follows the tube. Is anyone else having problems with these tubes? They normally run about 65v across the 1K cathode resistor. Is this too high of current for the EH tubes?
The stuff you don't know always humbles us.........
Old 29th November 2007, 12:02 AM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Hey, this is similar to a problem I encountered recently with my 300B!
I traced the problem to a faulty hum balance pot! I'm not sure what's the design of the Dared is but it may be worth looking at.
Old 29th November 2007, 12:27 AM   #3
Yes, it has a hum balance pot... What wattage pot did you use? I guess it's 100 ohms? It's very posible. Thanks for the reply...
Old 29th November 2007, 12:51 AM   #4
It used to have a 5W Clarostat (I think) I got from Farnell. I had it replaced by an over-kill 50W TDO.
Both are 100 ohms.
ps.
When measured for resistance, it did gave the right Rk value, so I was pulling hairs trying to diagnose it.
Old 29th November 2007, 03:15 PM   #5
t_blizzard's Avatar
Your new 50W trim pot could be inductive and causing intermittent oscillations.
Any reason for such overkill on the wattage rating?
Old 29th November 2007, 04:09 PM   #6
7N7 is offline 7N7  France
7N7's Avatar
Yes I was wondering this too.
On my p-p 813 amp I used to use 2W 100 ohm pots, but later changed to 25 ohm 5W as the 2W ones got noisy and someone gave me the 5W ones!
7N7
Plug them in and light them up
Old 30th November 2007, 04:36 PM   #7
The reason being Iis that I do not have any alternative at the moment. Intermittent oscillations? How does it manifest? How do I measure/test?
Old 30th November 2007, 06:09 PM   #8
t_blizzard's Avatar
Fair enough.
The biggest reason for most oscillating circuits is how they are wired.
All wires are antennas and can couple RF energy into a circuit.
Temperature can also trigger a tube circuit to oscillate.
You will need a scope to monitor for intermittent oscillations.
Old 30th November 2007, 06:09 PM   #9
kevinkr's Avatar
Default Re: Electro Harmonix 300b...shorting problems?
I have no direct experience of the EH 300B however I have had serious problems with other Russian made 300Bs which shall remain nameless. I have had intermittent grid connections which gave rise to similar symptoms to those described above, and I have also had filament to grid shorts that occurred and cleared as the filaments warmed up. (Saggy filaments)
Assuming the presence of grid stopper resistor the fact that it follows the tube is relatively conclusive, and I would replace it soon. The EH 300B is reputedly rugged and reliable so I would just try another one. Perhaps you can return it for an exchange if it is still under warranty.
Arnold actually wasn't the original thread starter having a problem with these tubes.
www.kta-hifi.net
Electro-Harmonix interview torrence Tubes / Valves 0 28th January 2009 01:38 AM
KT88 Electro-Harmonix N1ESE Tubelab 14 2nd November 2008 04:16 AM
Electro Harmonix KT90? georgehifi Tubes / Valves 73 11th February 2007 04:24 AM
Electro-Harmonix 6SN7EH DougL Tubes / Valves 5 1st March 2004 10:51 PM
Page generated in 0.12039 seconds (81.19% PHP - 18.81% MySQL) with 10 queries
