| diyAudio Sponsor | ||
Hi!
I just received on loan from a friend an Aikido line-stage. I must say this is to my ears a superb pre: very clean, open and transparent with a great soundstage and presentation of individual instruments. It uses 6BX7 as both in- and output tubes. I also have a 12b4a linestage (from a friend) that actually gets beaten in my set-up in all the above mentioned areas. However the 12b4a has somewhat better "drive" and also more mid-bass (which suits my set-up, don't know about neutrality). I'm thinking of making my first DIY amp using the octal Aikido linestage kit from John Broskie and Glass-ware. I understand one can choose between all the following tubes "the 6AS7, 6BL7, 6BX7, 6SL7, 6SN7, 12SL7, 12SN7, 12SX7, 5691, 5692, 6080, B65, ECC32, ECC33…" but "Both tubes must share the same heater voltage". And if I understand it correctly you need to make your choice of tubes before starting to build and choosing other components. Finally Thanks for reading! Johan
#2 | |
I would suggest doing a search and you will find a number of good Aikido threads that will answer your questions. I would suggest printing them out and putting them into an Aikido notebook for future reference.
The 6SN7 has very good drive and probably more than enough for most equipment without a doubt. |
#3 |
Hi burnedfingers,
I did a search and found a couple of interesting threads on tube choice. Actually I was offered to buy the Aikido yesterday and "modded" to use 6sn7. So this might not be my first DIY project after all... Thanks! Johan
| Aikido tube choice | peterr | Tubes / Valves | 25 | 12th July 2009 07:46 PM |
| Aikido 24V tube linestage | Sarchi | Swap Meet | 2 | 11th October 2007 11:12 PM |
| Aikido Linestage Project PCB's | Geek | Swap Meet | 2 | 5th October 2007 08:15 PM |
| 12b4 vs. aikido linestage | Klimon | Tubes / Valves | 2 | 14th August 2007 12:38 PM |
| Aikido linestage Help Needed | Cambe | Tubes / Valves | 5 | 16th March 2007 02:40 AM |
| Page generated in 0.07176 seconds (74.83% PHP - 25.17% MySQL) with 10 queries |
