| diyAudio Sponsor | ||
I just want to ask knowledgeable folks here about this biasing scheme and its application for using an IT (or in this example parafeed L-inverter w/ 2 CT connections)... This was posted in another forum by Kuei Yang Wang a few years ago: To quote him: "Drawn here is the output stage with hum balance pot and bias balance... Balance the voltages for the Grids... allows the halves to be separated to inject a few volt positive (in my example with the Amp balanced with perfectly matched valves around 2.4V into each grid) into the grid circuit so that varying this voltage balanced the current." Questions: 1.) How do you determine that the DC Bias is correctly adjusted? 2.) If I am to use a panel meter on the chassis how should it be wired/configured in the cirucuit and with least sonic penalty? A friend mentioned I need a Milliameter in between the Plates and the OPT. I could bypass the meter using a switch. Is this the only way? Thank you. |
#2 |
Hi Fred,
A mA-meter seems the solution. With a switch that allows to measure the current in each plate. And to switch off the measurement circuit when not in use. In my amp, I use indirect heated tubes (KT66) and I inserted a 1 ohm resistor in series with each cathode. The mV across these resistors give me the current in mA. It is a floating measurement. The cathodes are at 40V!!! Serge
'I have no faith in prayer that's not electronically augmented' Philip K. Dick "A Maze Of Death" 'I have no faith in bimbos that are not surgically augmented' Serge66 |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 06:26 PM |
| Bias problem- 1 Socket shows extremely low bias! | otokomae | Tubes / Valves | 12 | 31st December 2008 11:01 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 02:30 AM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 01:34 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 11:24 AM |
| Page generated in 0.06155 seconds (79.15% PHP - 20.85% MySQL) with 10 queries |
