| diyAudio Sponsor | ||
#11 | |
What part is B.S.?
"Any fool can know. The point is to understand" - Albert Einstein |
#12 |
I'm not thrilled with his approach, either. The main issue with the Williamson is LF stability, which is best addressed by coupling caps- if the time constants of the two RC couplings are staggered by 5:1 or more, the LF stability will be much improved. I wouldn't fool with the operating points; they are chosen for best linearity. A properly operating Williamson driver has more than enough capability to drive its output stage to clipping.
The writer is correct about replacing 12AU7 with something more linear. Changing the cathode bypass cap on the output stage will indeed extend the LF response. The cost is much worse overload recovery. If you're using a small tube amp to reproduce high level deep bass, I don't have much sympathy... edit: I see that this site touts "high slew rate capacitors." Res ipsa loquitur.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#13 |
| Pilot LED for my new car Amplifier | raghs | Car Audio | 11 | 27th March 2009 05:03 PM |
| Pilot SA 260 bias | baltimoreblues | Tubes / Valves | 1 | 3rd February 2008 06:00 PM |
| Flame On!: Tragic loss of magic smoke | KBK | Solid State | 28 | 29th October 2006 05:26 PM |
| pilot 264 | jaron | Tubes / Valves | 17 | 13th March 2006 03:32 PM |
| Magic Smoke (smells bad works good)(long) | Stocker | Chip Amps | 0 | 28th February 2005 11:44 PM |
| Page generated in 0.06570 seconds (69.30% PHP - 30.70% MySQL) with 10 queries |
