diyAudio Sponsor
Old 24th November 2007, 07:58 PM   #1
nesha is offline nesha  Serbia
Default 7591 se tube amp?
Hi , I was unable to find a 7591 se schamatics ( a la Zen) . This is great sounding , easy to drive tube, would give 3-4W in se configuration, has anybody tried it? I was advised to to try this simple calculation by myself, and I will , I promise, I just would like to have something somebody has tried already, thanks.
Old 24th November 2007, 08:51 PM   #2
Assuming 20% efficiency for triode wired 7591s, 3.8 W. is what you'll get. Max. plate dissipation for the 7591 is 19 W.
Circuitry that drives EL84s and 6V6s also drives 7591s. A 12AV7 family tube, fed directly by a CDP, will do very nicely driving 2X SE 7591s.
Use 3.5 KOhm or slightly greater primary impedance O/P trafos. Tie the screen grids to the plates with 330 Ohm Carbon comp. resistors, which act both as stoppers and as current limiters.
I leave the RC cathode bias network calculation to you.
7591 data sheet here.
Eli D.
Old 24th November 2007, 10:15 PM   #3
I found 7591 was superb in Ultralinear but quite boring as a triode. Maybe you should be looking at either UL SE or another tube?
Old 25th November 2007, 01:56 AM   #4
Thanks guys, I was hopping to get answer from you Eli, and you gave me exactly what I need. Thank you Endi too, I m always open for sugestions, what speakers did you try with 7591 se amp?
Old 25th November 2007, 01:13 PM   #5
I didn't have a SE 7591. I used it in push pull. I always loved that tube in PP since having a McIntosh amp that used them. I then tried it in triode and found it very ordinary - seemed to lose its tone and dynamics.
Using the 7591 or 7868 andyjevans Tubes / Valves 11 21st June 2010 05:53 AM
7591 is glowing RED dognut Tubes / Valves 2 1st March 2009 07:16 PM
Bias and max current for my 7591 AB amp... mr mojo Tubes / Valves 14 6th January 2006 03:50 AM
PSU for "2 Stage" PP 7591 Amp dhaen Power Supplies 1 1st December 2005 06:17 PM
PP 7591 amp HugoR Tubes / Valves 0 11th October 2005 09:08 PM
Page generated in 0.06223 seconds (83.02% PHP - 16.98% MySQL) with 10 queries
