| diyAudio Sponsor | ||
Hello all.
You might have noticed I have been asking questions about 6L6 and its cousins hereabouts. I have a pair of Croft modified Quad IIs; in place of the KT66s the amps are fitted with EL34s; additionally there is regulated voltage with 85A2/12AX7/6080. I have not yet found any diodes so perhaps half of the 6080 is used as a rectifier? Anyway having learned quickly just how hot the mains transformer gets, I decided that as EL34 wants 1.5A for its heater compared with 0.9A for 6L6 I decided to try to save 1.2A. I have received a pair of Sovtek 5881WXT; now it is said that 6L6 is a good idea in the Quad II, but that the bias resistor should be changed from 180 ohms (with KT66) to appx 220. I was surprised that the resistor is 180 even with the EL34s. So having adjusted HT voltage to the specified 340V (anodes of EL34s) I plugged in the 5881s and was very surprised to see 22V at the cathodes: identical to that measured with the EL34s. Screen voltage is just over 330V; so far the 5881s have not gone "phut". All in all, the easiest mod I have ever done. 7N7
Plug them in and light them up |
#2 |
22 Volts across 180 Ohms => 122mA or 61mA per tube.
At 340 - 22V across the tube => Vak = 318V Pa = 318 x 0.061 = 19.4 Watts per tube. That is a very conservative running point for 5881. They should last for years. Cheers, Ian |
#3 |
Hello,
Yes, just like the original KT66s they are really being under-run. It was the lack of data for the Sovtek WXT that was just a bit un-settling - in particular if the WXT could cope with 330V on g2, but I have since found out that Fender and Marshall use them in guitar amplifiers and recalling the voltages usually found in these I have no worries at all. I have read quite enough about eastern fireworks displays, though Tubelab's experiments were reassuring! 7N7
| Sovtek KT88 | overdrajv | Tubes / Valves | 10 | 18th May 2010 05:49 PM |
| Sovtek 6B4-G | Lowrider | Tubes / Valves | 11 | 25th February 2009 12:43 PM |
| FS:12AX7LPS SOVTEK 50 Pcs | rubydac | Swap Meet | 2 | 20th November 2008 05:28 PM |
| 2A3 Sovtek characteristics | teodorom | Tubes / Valves | 16 | 17th July 2005 12:29 PM |
| FS: 2A3 Sovtek | NickC | Swap Meet | 0 | 17th October 2004 01:52 AM |
| Page generated in 0.07649 seconds (68.98% PHP - 31.02% MySQL) with 10 queries |
