diyAudio Sponsor
Old 17th March 2008, 05:19 PM   #21
George Bush's Avatar
Send a message via ICQ to George Bush
I think four 6Ñ19Ï triodes per channel in class A will exceed maximum current ratings (140mA) on output power of 1.5W with 8 Ohm load. Am I wrong?
Old 17th March 2008, 05:26 PM   #22
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Use something like IRFPG50.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 17th March 2008, 05:29 PM   #23
adason is offline adason  United States
adason's Avatar
I have over 100dB sensitive speakers and I never use more than 200 mili watts ....
Old 17th March 2008, 05:29 PM   #24
Fuling is offline Fuling  Sweden
I believe you´re right. IIRC each tube in the SE OTL operates at 110mA, so the total quescent current is 440mA per channel (I might be wrong here). Assuming the current swings from cutoff to 2x440mA the output should be something like 0,7-0,8W @ 8R.
Just for the record: I have a DIY amp built by the same concept but with 4 x PL504 per channel and it sounds plain marvellous.
Currently I´m collecting parts for a new amp with 8 x 6S19 per channel, it should give something like 2x2,5W @8R and consume about 300W...
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
vt-25 single-ended eduard Tubes / Valves 5 22nd September 2002 03:45 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Page generated in 0.05977 seconds (80.32% PHP - 19.68% MySQL) with 11 queries
