| diyAudio Sponsor | ||
#2 |
if you are to measure the cathodecurrent it will be sufficient, but it'a not a tubetester if that's what you are looking for?
www.joddla.net/audio/ |
#3 | |
As Mr Triatic says, this will only enable you to measure cathode current. I should add that the ebay blurb states that "One of the problems with standard valve testers is that they do not operate at the high currents that guitar amplifiers generally do". Well of course there has been much written about valve matching; ideally they should be matched for emission and gm at the designed operating point. It is hopeless to expect to find valves that behave identically in the dynamic sense. The AVO 163 tester I had could provide up to 400V on anode and g2 and deliver 100mA. I would have thought that this would be enough for any guitar amplifier. Unfortunately good testers are costly and very few can provide the high g2 voltages that are often used in guitar amplifiers. 7N7
Plug them in and light them up |
| Matching Tester | djoffe | Solid State | 1 | 23rd August 2009 07:58 PM |
| Scosche SPL meter: Cheap find with potential, or cheap junk? | theAnonymous1 | Everything Else | 5 | 11th October 2006 03:40 AM |
| Have you seen this tester? | smak | Tubes / Valves | 30 | 28th January 2006 06:43 PM |
| uC DAC tester? | emuman100 | Digital Source | 40 | 23rd July 2004 04:08 AM |
| Page generated in 0.06594 seconds (69.83% PHP - 30.17% MySQL) with 10 queries |
