diyAudio Sponsor
Old 20th November 2007, 05:23 PM   #1
PRNDL is offline PRNDL  United States
Default rusty chassis - what to do?
I have an old Precision (Western Electric) mono amp that has a fair amount of surface rust on the chassis. Nobody will see it when it's inside its metal box.
I could steel wool and scrape it off, but the black painted lettering would come off as well. The lettering is on a dirty part of the chassis that's not very close to the rust.
The circuitry is fantastic - high end caps, military style wiring. Replacing or removing the chassis for cleaning/refinishing is not really worth the effort.
I'm thinking of using steel wool on the bad parts and coating it with clear. It won't be beautiful and shiny, but it would be nice and protected.
Also, someone spray painted the outer chassis (a square metal box) in ugly red.
Do you recommend stripping the paint and repainting?
How does one strip it (chemicals or sanding)?
What would you recommend?
Thanks!!
Old 20th November 2007, 05:42 PM   #2
Tom Bavis's Avatar
Try lacquer thinner to strip the paint - it's worked for me. OUTDOORS!
As for the rust... not a whole lot you can do. You can strip the chassis down to bare metal and use electrolytic rust removal... probably will remove any paint and plating though... (google for more). A less drastic approach is to use a rust conversion primer (phosphoric acid based - auto parts store) to stabilize the rust and then paint with aluminum or other silver paint. The latex based primer won't protect it without additional paint.
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 14th December 2007 11:41 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 05:37 PM
rusty iron- need help :) karma Tubes / Valves 5 18th June 2004 12:53 AM
chassis audioman Pass Labs 11 8th May 2003 04:28 PM
Page generated in 0.07428 seconds (72.98% PHP - 27.02% MySQL) with 10 queries
