Where to find data sheets?
Old 20th November 2007, 03:05 PM   #1
Zap is offline Zap  United States
Default Where to find data sheets?
I've been looking around, after much consideration, and I think my first amplifier project is going to use either the Tung Sol 6550 or EH KT-88. However, I have not had much luck finding a real data sheet for either of these tubes.
Isn't there enough change between manufacturers that one would want the actual mfr. data sheet? Can anyone maybe point me in the right direction?
Right now I've considered the TubeLab SimpleSE as well as trying to roll my own design. Even if I don't try building from scratch first, I'd still be interested in running through the steps.
Any comments on these two tubes is also welcome. The TS is the new Russian version, as the NOS is a bit more than my budget can take right now.
Thanks!
Old 20th November 2007, 03:23 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I used Google with the keywords tube and datahseets, tested that?
http://frank.pocnet.net/
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 18 pcb's in interest so far.
Old 20th November 2007, 03:40 PM   #3
Yeah, just no luck looking for the specific manufacturers. Is the data from another manufacturer good enough to use for design calculations?
Old 20th November 2007, 06:12 PM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Yes.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 20th November 2007, 06:38 PM   #5
hbi is offline hbi  Romania
http://www.jogis-roehrenbude.de/
Where to find data sheets?Hide this!Advertise here!
RCA RCP20N50 & RCP10N50 Data sheets? mosfets Solid State 3 26th September 2008 12:40 AM
Power Transistor data Sheets... where to find Harlan Parts 3 21st February 2004 03:03 PM
Data sheets for japanese transistors? Cradle22 Parts 2 8th September 2003 11:22 AM
M5238 data sheets??? Christer Parts 5 30th March 2003 04:07 PM
Japanese data sheets HarryHaller Solid State 1 16th May 2002 06:54 AM
Copyright ©1999-2017 diyAudio
