| diyAudio Sponsor | ||
They've got 282X power transformers (500V .2A), 193J chokes (10H .2A), a socket for vacuum rectification, 60W 6.6K UL output transformers, and two other octal sockets. Is a 60W KT88/6550 amp feasible? At the moment I've got KT77's in there, cathode biased at 380Va 64mA with 5R4GYB's in the rectifier spot..
One thing: My B+ reservoir cap is only 100uF, albeit a motor run cap so it should have good transient response or something? I'd be willing to mount a little negative supply transformer on the bottom, some of which I could tap to feed a CCS in an LTP, if I wanted to try that. What do you think? |
| 807 monoblocks | sarrisk | Tubes / Valves | 13 | 28th August 2008 08:04 PM |
| Beefing up the power supply | whitelabrat | Tubes / Valves | 9 | 16th November 2007 07:23 PM |
| UCD-180 Monoblocks? | audioferret | Class D | 44 | 12th March 2006 09:48 PM |
| Need advice beefing up my Froys (wmtmw?) | MarkB1 | Multi-Way | 16 | 10th March 2005 05:20 AM |
| Beefing up EL34 PP | effindi | Tubes / Valves | 6 | 17th October 2003 06:38 AM |
| Page generated in 0.05848 seconds (65.38% PHP - 34.62% MySQL) with 10 queries |
