diyAudio Sponsor
Old 19th November 2007, 06:52 AM   #1
lpd is offline lpd  Canada
Default Question
was surfing and found a local vendor claiming that a 6SL7 can be swapped with 6SN7 in a preamp. I can see how the buffers can be rolled but am unclear about the drivers.
Any thoughts?
http://www.space-tech-lab.com/SP-QA-114.html
Old 19th November 2007, 09:27 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
It will probably "work".. i.e. amplify.. but not as intended. depends..
Old 19th November 2007, 07:32 PM   #3
I just don't get how the tubes are interchangeable? One seems to be half the mu of the other. Only thing I can think of is if they are used as buffers with a ss front end?
Old 19th November 2007, 08:19 PM   #4
Miles Prower's Avatar
Default Re: Question
Any thoughts?
Yeah, you found a local vendor with a surplus of 6SN7s and a deficit of honesty. About the only thing that's similar between these two types is the pinout. Otherwise, no comparison. 6SL7s have a u-factor of 70, a Pd rating of 1000mW. The 6SN7 has a u-factor of 20, and, at least the "B" version, a Pd of 5.0W. The Q-points are not likely to be anywhere near close.
There are no foxes in atheistholes
www.dolphin-hsl.com
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.07436 seconds (76.02% PHP - 23.98% MySQL) with 10 queries
