diyAudio Sponsor
Old 19th November 2007, 05:50 AM   #1
6f6 is offline 6f6  United States
Default Screen Supply For PP Amp
If I'm going to build a Push-Pull amp with a quad of 6v6 operated in "pentode" mode with fixed bias, I know that this amp will need a regulated source of screen voltage- most likely an 0D3 and a 0C3.
My question:
Would it be best to use one common screen supply for all tubes, or would it be better to use one gas reg or zener stack for each side of the push-pull arrangement?
Old 19th November 2007, 07:22 AM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
Theoretically, a single regulated screen supply should do it. It would have to have a pretty low impedance and I don't think you'd succeed with a single VR tube stack. An active regulator would be my choice for a single screen supply. BTW, if you regulate the screens, then you should also regulate the fixed bias supply.
Old 19th November 2007, 07:38 AM   #3
I'm interested in this too.
Why should we regulate both? And is it really neccessary to regulate?
I don't have any intention to argue , I'm really new in this.
Cheers
Audio_Idiot
Old 19th November 2007, 07:53 AM   #4
Miles Prower's Avatar
Plate current varies with both screen and grid voltages. If you nail one down, but let the other vary, the plate current varies along with the wandering voltage.
No, and there have been lots of commercial designs that don't include screen regulation. However, it's been known since at least the mid-1930s that pentode amps operate with greater linearity and less distortion if you regulate the screen voltage. My own preference for this is an active screen voltage regulator. I've done two different designs with power pentode finals, and included hollow state, series pass screen regulation.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 19th November 2007, 08:07 AM   #5
Hi Miles,
I had a shunt regulated screen supply for my 832 for a different reason, the grid2 voltage accent over time and the current along with it
What about autobias?
Cheers
Audio_Idiot
PP pentode screen supply ray_moth Tubes / Valves 43 5th August 2009 01:12 AM
Question about a VR screen supply athos56 Tubes / Valves 23 28th February 2009 03:09 PM
Regulated screen supply mashaffer Tubes / Valves 5 3rd September 2008 03:41 AM
Maida for Screen Supply avincenty Tubes / Valves 15 20th May 2008 03:37 AM
Page generated in 0.07434 seconds (71.69% PHP - 28.31% MySQL) with 10 queries
