| diyAudio Sponsor | ||
A couple of times I've seen datasheets where cathode resistor in "typical operations" was significantly smaller than in "RC coupled amp table". I understand you can bias it any way you like but still cannot understand what's the story.
examples: 5670 - double triode. see page 3: cass A1 amplifier, cathode resistor = 240 ohm. in class A RC coupled amplifier table below the lowest cathode resistor is 900 ohm. 5719 - submin triode page 1: characteristicsn- plate 100V, cathode resistor = 1.5K. page 6: RC coupled amp - plate 100V, cathode res. = 2.7K and higher. 5718 - submin triode characteristics: cathode 150 ohm - plate 100V RC amp - cathode 1K and higher (under 100V) I'm sure I am missing some point. Why is that difference? |
#2 | |
Lots of VT specs also suggest typical circuits. I ignore these completely, and design based on loadlines. Most of those sample circuits are based on 5.0% THD, which is pretty awful. Nor is it always possible to use the specified Vpp. I can do better by picking my own Q-points and distortion figures from the plate characteristics. Consider it to be nothing more than a cheat for lazy designers. |
| capacitor coupled vs. direct coupled ouput | hugobross | Solid State | 11 | 21st January 2011 01:56 AM |
| 6sn7 direct coupled and transformer coupled | neazoi | Tubes / Valves | 3 | 23rd May 2008 03:30 PM |
| Typical 2A3 hum? | bobhayes | Tubes / Valves | 31 | 17th October 2005 01:12 PM |
| Just your typical DIY enclosure.. | ScottG | Multi-Way | 2 | 10th July 2005 10:44 PM |
| Can someone explain parafeed & direct coupled & a.c. coupled? | mwmitchell | Tubes / Valves | 2 | 11th September 2002 01:10 PM |
| Page generated in 0.07904 seconds (72.89% PHP - 27.11% MySQL) with 10 queries |
