| diyAudio Sponsor | ||
Hi, this is an integrated amp from Dared that was working perfect until a couple of days ago when the left channel suddenly died, there is no hum, no distortion, nothing, I canīt see anything burned or loose, all I can tell you is that the KT88 in the faulty channel barely gets warm, the other KT88 gets very very hot, or course I tried changing tubes, but it seems that the KT88 is not getting enough current to heat the filament or something similar, what is a safe way to measure this? thanks guys! ah the other tubes are 12AU7, 12AX7 and the one in the middle is a 6HU6. |
#2 |
diyAudio Chief Moderator
Get a multimeter, set it for AC and see what it reads between pins 2&7. Who put Auricaps and the red electrolytes (Cerafines? BGs?) in there?
#3 |
the auricaps and cerafines are stock, not bad for a Chinese amp, right, I will take the measure tomorrow, thanks, what would be a normal reading?
#4 |
5.7 - 6.9 VAC. 6.3 VAC nominal.
| Help for correct grounding a Dared VP-845 | andreas w. | Tubes / Valves | 2 | 7th June 2008 07:25 AM |
| Page generated in 0.06711 seconds (71.29% PHP - 28.71% MySQL) with 10 queries |
