Using relays in high voltage circuits
Old 18th February 2003, 12:08 PM   #31
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default TUBES ON THE RUNWAY.
Why would an unpressurised hold cause thermal runaway later?
Dunno really, it was the only explanation we could come up at the time.
Absolutely nothing was wrong with the amps electrically, the valves were replaced and the problem was gone.
Strange...
Frank
Old 18th February 2003, 10:20 PM   #32
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Only thing I can think of is the low pressure stressing the envelope less, and the changing stress wrecked the vacuum somehow...
Considering the glass is made with equal pressures on either side, and is constructed to have a constant compressive force (about 14PSI, i.e. atmospheric vs. zero), then reducing that force - but clearly not reversing it - can't possibly break the seal.
Were the getters still good before turning it on?
Tim
Old 18th February 2003, 10:30 PM   #33
On Hiatus
SY's Avatar
Default Re: TUBES ON THE RUNWAY.
Strange...
Post hoc ergo propter hoc?
More likely the handling by the chimps working for the airline, I'd expect. Unpressurized cabins didn't seem to bother the tubes used by the Soviets in some of their avionics.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th February 2003, 10:39 PM   #34
fdegrove's Avatar
Default PSI.
The amps and valves were fine when they left the U.K.
Actually,what may have been the cause of the trouble is the PSU caps in the HT rails not being too happy with the sudden change in atmospheric pressure.
None of the output tubes showed any sign of leakage or air ingress whatsoever...
I think the PSU somewhat got unstable and I was left with a handful of blown fuses (a handful of sand really), endcaps of fuses molten into the partially carbonized fuseholders and a lot of those lovely RCA 6080s with at least one halve of the double triodes gone.
Don't worry too much about it though,
Frank
Using relays in high voltage circuitsHide this!Advertise here!
High loop Gain Composite Op Amp Circuits jcx Solid State 43 9th September 2015 01:24 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 16th December 2006 12:52 AM
Voltage doubler/tripler circuits diablo Power Supplies 6 4th October 2005 05:43 AM
Voltage regulators for line level circuits HarryHaller Solid State 64 24th April 2003 06:45 PM
