Using relays in high voltage circuits
Old 16th February 2003, 12:41 AM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
IMO The best "relay" for this is a valve.
Old 16th February 2003, 12:49 AM   #12
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default BEAT ME.
Yes...
And the I.Q. is going down lately....pffffrrrrhhh.
\signed HH style.
Frank
Old 16th February 2003, 01:06 AM   #13
Gunders is offline Gunders  Norway
Well.. here you have a schematic of the alternative....
Old 16th February 2003, 01:16 AM   #14
dhaen's Avatar
Frank,
I thought my reply was succinct.
Valves make very good relays, as do transistors. Exhibit 1: the computer I'm presently typing on.
But valves come in high voltages.
You could be right about the IQ. After all, I'm at one with the Belgian, French, German position over Iraq. And we all know that the "cleverest" people are American (with the Brits up their **** of course). After all, only stupid people don't want to go to war...
Old 16th February 2003, 01:24 AM   #15
Boxbldr681 is offline Boxbldr681  United States
It will work fine, but add a little trick to keep the spark from pitting your contacts. Add a .01 1KV cap between your contacts [top to bottom I assume] and a .001 1KV cap from bottom contact to ground to keep things from sparking. Maybe not the best setup but will work and with this voltage may not need it at all, better safe than replacing relays someday.
Old 16th February 2003, 01:24 AM   #16
dhaen's Avatar
Why not replace the relay with a valve with grid and cathode connected together?
OK it'll need it's own heater supply.
Tada... a delay. (If that's what's needed...)
Protel eh?
Old 16th February 2003, 01:29 AM   #17
fdegrove's Avatar
Default COMBUSTED.
It will work fine
Yep.
And I can write Chino too.
For crying out loud ,you don't have a clue what it's about .
Yep.Yep.It was was.
Frank
Old 16th February 2003, 05:15 PM   #18
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
You can get a relay from P&B with 600VAC contact rating (T92 series - 10A@600V, 30A @240v...) for about $8-10 US from DigiKey or Mouser. It's an ugly black plastic case with mounting flanges and tab terminals, but you were going to hide it under the chassis anyway... right?
Old 16th February 2003, 06:02 PM   #19
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default in the kw ham amplifiers
they switch the ps primary -- actually DPDT and a safety interlock -- microswitch -- so that you can't engage the relay without the cabinet being closed.
i have seen the center tap of a transformer secondary switched in and out as "standby".
Old 16th February 2003, 08:38 PM   #20
Originally posted by dhaen
Protel eh?
Yes, I use Protel for drawing schematics and PCB layouts, though I only use the Protel 99SE, I haven't got a crack for the Protel DXP version yet.
I know some of you don't like the PCB thing.
Back to the relays....
The conclusion is that it's ok for me to use a relay the way showed in the schemtic I posted as long as I add some protectioncapacitors?
Are there other thing I should be aware of while using relays in high voltage circuits.
And the thing about using vacuumtubes instead of a relay, I don't quite understand.
Wouldn't there be a quite large voltage drop over the tube, and how much current can I accept through this tube??
Originally posted by jackinnj
I have seen the center tap of a transformer secondary switched in and out as "standby".
Yes, I have also seen switches connected to the centertap, but unfortunately my transformer don't have a centertap.
But wouldn't it be a problem to use 'normal' switches in high voltage circuits too??
Using relays in high voltage circuitsHide this!Advertise here!
High loop Gain Composite Op Amp Circuits jcx Solid State 43 9th September 2015 01:24 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 16th December 2006 12:52 AM
Voltage doubler/tripler circuits diablo Power Supplies 6 4th October 2005 05:43 AM
Voltage regulators for line level circuits HarryHaller Solid State 64 24th April 2003 06:45 PM
Copyright ©1999-2017 diyAudio
