Old 16th February 2003, 10:30 PM   #21
diyAudio Senior Member
fdegrove's Avatar
Default PROBLEMS ABOUND.
But wouldn't it be a problem to use 'normal' switches in high voltage circuits too??
Normally you only have to consider the current ratings of that "normal" switch.
Unless specified explicitly you can derate easily using Ohm's law.
With relays it is a different story, if you consider what they consist of I'm sure you'll understand why.
Frank
Old 16th February 2003, 11:19 PM   #22
316a is offline 316a  England
316a's Avatar
Default Thermal Delays
Out of interest , would a tube thermal delay such as VLS631 be ideal or are these things too puny ?
316a
Old 16th February 2003, 11:31 PM   #23
fdegrove's Avatar
Default RETARDED ME.
I never heard of the VLS631, but anyone smart enough can build a hybrid rectumfryer providing the best of both worlds.
1/Vacuum tube rectifiers have slow start built in.
2/I use solid state rectification and still want a slow turn on, what to do?
A:use a thermistor, use a tube voltage reg.,use your hands and switch the heaters on prior to the B+...
Countless possibilities really, a relay would be the last of my options.
BTW, only when solid state rectification is used can a turn-on delay be justified....most of the time though I can't be bothered.
Frank
Old 16th February 2003, 11:52 PM   #24
316a's Avatar
Default Hybrid Rectums
Hybrids work fine , I have found that the otherwise useless PY500a with solid state works particularly well . Even the solid state 'gyrator' or 'active capacitor' has it's uses , I've never had luck with mosfets here and my bipolar darlington design goes west over 400V but they do work very well if you don't take the **** out of them . A PSE 845 amp with a large 'frankenstein' knife switch on the HT would really get the adrenaline flowing though !
316a
Old 17th February 2003, 03:50 PM   #25
slowmotion's Avatar
Ahh, cool
- Jan -
Old 17th February 2003, 10:02 PM   #26
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default More delay
Although valve rectifiers switch on gently, they don't necessarily give all the delay you need. Putting a thermal delay relay in series with the rectifier's heater adds the two delays together and ensures a nicely delayed soft start for fragile valves like 6528.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 17th February 2003, 10:07 PM   #27
fdegrove's Avatar
Default FRAGILE?
Really?
I'd like to know more about that,pls.
Frank
Old 17th February 2003, 10:18 PM   #28
EC8010's Avatar
Default Fragile 6528
Yes, in the Tung-Sol/Chatham data sheet, the Application Notes recommend a 30s cathode warm-up time before applying anode volts. But I've measured valve rectifiers beginning to conduct rather sooner than that...
Old 17th February 2003, 10:54 PM   #29
fdegrove's Avatar
Default 6528.
Well yes, most regulator valves suffer from this actually.
Come to think of it, low Ri, low mu, highish transconductance...asking for trouble when the B+ is slammed on, right?
The biggest mess I was ever in was when my amps were flown back in from Birmingham and as I lived only ten miles from the airport I switched them on half an hour later.
Wow...they all went into thermal runaway within ten minutes.
Stupid really, should have thought about the luggage department not being pressurised.
Frank
Old 18th February 2003, 09:41 AM   #30
EC8010's Avatar
Default Re: 6528.
Yes, I wondered whether this might be a universal problem for high gm valves. Anyway, I've come to the conclusion that unless you are using disposable valves, there always ought to be provision for being gentle at start-up.
Am I missing something obvious here? Why would an unpressurised hold cause thermal runaway later?
High loop Gain Composite Op Amp Circuits jcx Solid State 19 1st February 2013 08:05 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
Voltage doubler/tripler circuits diablo Power Supplies 6 4th October 2005 04:43 AM
Voltage regulators for line level circuits HarryHaller Solid State 64 24th April 2003 05:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
