| diyAudio Sponsor | ||
Hi dudes.
I got a pair of 3,2K/8Ohm, 100mA OPT, but i'm a bit reluctant choosing the rite tubes for it. Any ideas which one should I go with? probably easy with EL34, 6B4G, but I'm thinking of EL34 PSE, not sure if the OPT can handle 2 EL34/channel? Any comments are appreciated. Thanks. |
#2 |
A 300B with 350 V. on the plate, - 74 V. on the grid, and IB = 60 mA. working into a 3 KOhm load yields 8.3 W. 3.2 KOhm is certainly close enough for the load.
You could go the combination bias "route", with an unbypassed 330 Ohm resistor under the cathode and the rest of the bias voltage coming from a negative supply. The local current NFB (degeneration) associated with the unbypassed cathode resistor raises the effective plate resistance, which would mate nicely with that "extra" 200 Ohms. The improved linearity local NFB yields aids the cause too.
Eli D. |
| Tube Noob! need help with tubes lots of tubes | therapy_fan | Tubes / Valves | 15 | 29th January 2009 09:01 PM |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| Tubes! | Geek | Swap Meet | 4 | 16th May 2008 06:20 PM |
| CV428 tubes (Loktal 807) tubes FS | mobyd | Swap Meet | 3 | 2nd January 2008 11:26 AM |
| many new tubes and tubes meter for sale | elviukai | Swap Meet | 4 | 30th October 2003 09:22 AM |
| Page generated in 0.05865 seconds (70.64% PHP - 29.36% MySQL) with 10 queries |
