diyAudio Sponsor
Old 13th November 2007, 05:07 PM   #1
Question AH NJoe TJOEB, valve compatibility issue
I have a AH NJoe tjoeb 4000 CD player, and running it are a lovely pair of old, (now even older) at the time new stock, Telefunken EC88/6DJ8,s.
Im cringing and waiting for them to give up the ghost, as it has been 4 years since i bought them.
They have been used many times, and they sound beautiful. So, I searched on the web for some info, on compatible tubes, one guy quoted on a post , "you can try any tube with the AH, as the Tubes only add colour to the sound, and do not have a major functional role. any valves with a 9 pin, will work!.
So, looking for some fun I bought a cheap pair of ECC83/12ax7 JJ /Tesla Amplifier Valves. just as a standby, and tryout pair, until i can afford some better ones.
On power up, there was a mush of muffled fluttering distorted sound, and i switched it off sharply. I have some stock philips tubes, Jan 9772. They and the Telefunkens work perfectly.
Were the tubes incompatible?, are or the tubes a crock of ****, or have i been told the wrong advice?.
Any comments would be greatly appreciated, i am just happy that my Cd player still works, but googling has not been to fruitful, for the 3 hours i have searched for a list of compatible valves
thanks for any answers
Old 13th November 2007, 05:24 PM   #2
kevinkr's Avatar
Wrong advice.. The only nine pin tubes that will work are ones related to the 6DJ8 family with the same pinout. The ECC81-83 family are not compatible..
Some that might be (At least they are plug compatible):
6BK7
6922 (US Industrial type. Amperex good)
7308 (US Industrial type. Amperex and Sylvania generally good)
6N1P (Russian type has higher filament current)
E88CC (SQ Amperex, Philips Miniwatt)
JJ ECC88
Old Tektronix tube scopes often have scores of Telefunken 6DJ8 in them. In my experience these tubes are pretty long lived so you may yet have years of life left in the pair you have.
I have found in some instances that 6BK7 sound pretty good in applications calling for 6DJ8, but this is not universally the case. They are very inexpensive and hence worth trying.
www.kta-hifi.net
Old 13th November 2007, 08:23 PM   #3
eeek, everytime i ask something on here its for reasons of me nearlly destroying my hifi, but luckily its all working ok, and thanks Kevin for that info. I am now looking at some 6BK7,s on ebay, they look so cheap it would be worth the fun.
but i do hope my telefunkens last a long while, as, once that sound dies, its gone, unless i could ever find some Telefunken 1968 vintage ECC88. Maybe.
Old 13th November 2007, 09:06 PM   #4
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
I wouldn't bother with Ebay for this...
A couple of premium ones should be around 30£ from a regular supplier - cheaper ones down to maybe 10 £ pair.
There shold be plenty of them in old yUK.....
Old 14th November 2007, 03:28 AM   #5
kevinkr's Avatar
Around here eBay is pretty much the only choice, no local hifi tube vendors and the MI crowd sell current production tubes at highway robbery sorts of prices. I do buy from New Sensor when I need current stuff, but that's not often given what I use in my projects.
www.kta-hifi.net
Old 14th November 2007, 03:56 AM   #6
Actually, the same can be said of here, its cheaper for me to buy from the netherlands, germany, and eastern europe, than the, cant even say local, suppliers. As they are miles away and way overpriced.
Well, as you gave me a list of tubes that are compatible, for the Ah njoe Tjoeb, Kevin, i bought some cheap valves off ebay.
Not as a serious replacement for the Telefunkens, as when the times comes, i will spend , im sure a £100 on them both, at least.
but i found these, and if they sound better than my philips, Jan 6992's that come with my Tjoeb, i will be mildly happy.
6BK7 GENERAL ELECTRIC , two for £8 (new old stock)
6N1P-Vi / 6N1P Vi / ECC88 Russian Tube NOS MATCHED QUAD £10, New old stock, but worth a go
Electro-Harmonix 6922 GOLD PLATED PINS Valves £20, per pair, (heard some good feedback about these, i think these may do as stand ins, when the telefunkens die.
As i say just a bit of fun, as I have also, posted elsewhere about the Telefunken ECC88's, and many people reckon, that they will last a while yet. im just happy they lasted this long
AH Njoe Tjoeb CD player, valve Compatibility emperor Digital Source 0 13th November 2007 05:15 PM
Ah Njoe Tjoeb 4000 problem emperor Tubes / Valves 9 30th October 2007 05:06 PM
Njoe Tjoeb upsampler and balanced output jax8308 Digital Source 3 22nd April 2006 04:47 PM
Upsampler for Njoe Tjoeb - theory of operation rsrphotos Digital Source 2 2nd April 2004 06:46 PM
Njoe Tjoeb 4000 vs RESPONSE AUDIO Signature CD-25 Tube Modified HDCD Player scientist1 Digital Source 1 5th January 2004 08:13 AM
Page generated in 0.09047 seconds (80.21% PHP - 19.79% MySQL) with 10 queries
