| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
A few questions about the 807 amp below: http://tinpan.fortunecity.com/saints/668/primer/
What does the circuit between the 807 grid leak resistors do (with bias pots etcetera) + where does the arrow go (I figure the one above is B+ and the other one is indicated "to other channel" which strikes me dumb). Any thoughts? Thanx Simon |
#2 |
These are the bias adjustment pots. The one on the left sets the output tube current for the channel shown. The pot on the right sets the tube current for the channel not shown in this schematic (the other channel). The wiper of this pot goes to the 2200 uF cap in the other channel. There is actually one pot per channel. The arrow above goes to the -100 volt supply shown at the bottom of the page.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
Negative grid bias, offcourse.
Cheers, Simon |
| Thread Tools | |
| primer for fiberglass | pjoseph | Subwoofers | 5 | 4th August 2009 12:03 AM |
| A cooling Primer? | Pbassred | Solid State | 9 | 29th March 2007 06:00 PM |
| Help me pick a good primer for my box | ma_tt316 | Subwoofers | 5 | 4th December 2005 01:57 PM |
| Duncan Munro Psud primer please? | aletheian | Tubes / Valves | 4 | 13th September 2005 07:27 PM |
| Loudspeaker primer for the novice | Stephen | Multi-Way | 16 | 17th December 2003 02:01 PM |
| Page generated in 0.19359112 seconds (53.64% PHP - 46.36% MySQL) with 10 queries |
