I have 0 to spend..what amp should I build?
Old 8th November 2007, 01:31 PM   #1
humanhuman is offline humanhuman  United States
Default I have $250 to spend..what amp should I build?
Hi, I am new to building tube amps. I can read schematics and am looking for a good push-pull AB amp. I want 15 watts or more of power. I am interested in best sound quality (I know its subjective, but that is what I am aiming for). Anyone have a particular design they think sounds great? I am open for any suggestions, thanks.
Old 8th November 2007, 01:59 PM   #2
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
I think you'll find it tough to build a STEREO amp for $250 - transformers alone could exceed that. But if you're willing to scrounge some used parts, it could be done...
EL34 or 6L6 can give you 20W or more in class A. 6BQ5s or similar can be done for less, if 10-12W is enough (Some rated them at up to 18W, but they were exceeding the tube's voltage ratings...)
If you've never built anything like this, rebuilding an old amp (even one from a stereo console) is a good first step.
Old 8th November 2007, 02:00 PM   #3
On Hiatus
SY's Avatar
How good are you at scrounging parts from surplus? Aiming for "best sound quality" "15 watts" and "tubes" is a challenge at $250 if you have to source all new parts.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th November 2007, 02:26 PM   #4
jduffy is offline jduffy  United States
jduffy's Avatar
Default I remember reading about a cheap amp somewhere
There's something called "El Cheapo" based on a schematic and some guys who can help you. I forget what the specs were or the total amount of money you would need to spend in order to build it.
Do a quick search in Google and something should pop up.
Old 8th November 2007, 03:05 PM   #5
Thanks guys. I will do some hunting around online. I have a friend who has a bunch of old output transformers and some tubes and old enclosures so a lot of the more expensive parts will be pretty cheap to me.
Old 8th November 2007, 03:27 PM   #6
Tom Bavis's Avatar
The "el cheapo" circuit can deliver a few good watts, but not 15, regardless of output tube - since it uses them triode-wired. With pentode or ultraliner wiring, it would need some negative feedback to lower the output impedance - and I don't think there's enough extra gain for that. Add another stage, and it would be fine - you'd have the EICO circuit.
Find some good-sized output transformers, 3K to 8K center-tapped, and work from there. Better to buy the power iron - it's cheaper - than to try to match outputs to what you have.
Old 8th November 2007, 04:05 PM   #7
rdf is offline rdf  Canada
rdf's Avatar
If you have time every once in a while stereo jukebox amps show up on Ebay. Mine is a Rowe R-4359A that went for $50 plus shipping, decent iron.
Ears aren't microphones.
Old 8th November 2007, 11:34 PM   #8
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
The K-12 / K-502 Tube Amplifier Kits will fall within your budget once you add in shipping and an enclosure. They are good little amps, but fall short of your power request (15W). They are rated at 8W, but beyond 4-5W, I hear too much distortion.
Be warned, once you build one, you will be looking for more and bigger budgets!
Old 8th November 2007, 11:57 PM   #9
d to the g is offline d to the g  United States
d to the g's Avatar
I'd check out the tubelab simpleSE. "could" be done for $250.
Old 9th November 2007, 12:50 AM   #10
Eli Duttman is offline Eli Duttman  United States
The "El Cheapo" schematic is here.
You can get approx. 15 WPC from that topology in 2 ways: ultralinear mode "12" W. O/P tubes and triode mode 7591s. 7591s will require about 425 V. of B+. The 12AT7 splitter/driver has enough gain. Please observe that 9% of the speaker drive voltage is returned as loop NFB.
$250 is unrealistic for all new parts, including "iron". Copper and other commodity prices have been on the rise. If you can get your hands on a pair of recycled O/P trafos (with UL taps) from either a 6BQ5 or 6V6 amp at little or no expense, that $250 goal can be achieved. Jim McShane has bundled the necessary "small' parts into kits at fair prices. Look here. A highly satisfactory power "iron" set can be purchased at modest cost from Allied Electronics. I enumerated the necessary items and their costs, here.
Eli D.
I have 0 to spend..what amp should I build?Hide this!Advertise here!
How much do you normally spend on parts to build a good crossover pjpoes Multi-Way 12 2nd January 2007 05:41 PM
400 to spend on a first DIY system VvvvvV Multi-Way 0 21st August 2004 06:40 PM
If you had $150 -$200 to spend what Midrange/midbass would you buy? jainbaby Multi-Way 7 18th September 2003 08:41 AM
if you had $1000 to spend on two towers, what would you get? clipper10 Multi-Way 0 4th April 2003 06:01 AM
Copyright ©1999-2017 diyAudio
