diyAudio Sponsor
Old 7th November 2007, 09:32 AM   #1
Default Testing tube for noise
Hi!
I need some EF83 (or EF86) for my tube preamp. When i bought this small pentodes before, i noticed that some of them were very noisy and needed some testing.
This time i found another seller who offers testing so i will ask him to test noise (and maybe microphonics) for me.
I would like to know more about how this test; how it is done, can it be done with the tube tester etc...
Old 7th November 2007, 10:01 AM   #2
Geek's Avatar
The noise test is done by taking a sample from the anode load resistor (or CCS) and amplifing the output to a speaker (or eye tube).
Some testers have settings for this test that more resemble actual operating conditions, rather than "full throttle current" as typically done for life-test.
That simple
Cheers!
Old 7th November 2007, 10:10 AM   #3
Thanks. I expected simple procedure.
But what are the "values" of noise for this kind of tubes? Datasheet for EF86 only tells noise voltage at certain frequencys...Should i ask him to simply send me tubes that showed lowest noise?
Cheers!
Old 7th November 2007, 10:40 AM   #4
jackinnj's Avatar
with a simple amplifier setup and an RMS voltmeter measure the A.C. output with the input open and shorted -- calculate the ratio take its logarithm multiply by 20 etc. gives you the voltage signal to noise ratio in dB.
Good discussion of tube noise here:
http://www.john-a-harper.com/tubes201/#Noise
if you were doing this commercially you would probably want to bandwidth limit the measurement -- say from 22 Hz to 22kHz -- or ITU-CCIR486-ARM or A Weight the measurement. Beyond the scope of this discussion.
Old 7th November 2007, 12:13 PM   #5
Tubes4e4's Avatar
Hi rotation,
Here is a Link to a DIY tube microphonics tester, in German language, though.
Regards, Tom
If in doubt, just measure.
Testing Gm without tube tester zigzagflux Tubes / Valves 19 21st October 2010 08:00 PM
Testing for tube shorts Zero Cool Tubes / Valves 3 31st May 2008 08:48 PM
Tube testing questions zigzagflux Tubes / Valves 3 24th April 2007 11:52 AM
testing distortion/noise on a X'd amp? rif Pass Labs 1 18th August 2004 06:23 PM
learning, building and testing tube amp fragman56 Tubes / Valves 103 11th March 2003 10:53 PM
Page generated in 0.06679 seconds (80.73% PHP - 19.27% MySQL) with 10 queries
