Optimal Umbilical Runs and Connections
Old 7th November 2007, 05:08 PM   #11
ckniker is offline ckniker  United States
Where is the best (i.e. cheapest) online place to buy about 2 meters of Belden 1037a?
Chris
Old 7th November 2007, 05:14 PM   #12
JoshK is offline JoshK  Canada
Great ideas guys! I learned a few things as usual.
I especially like the loopback idea. I was thinking instead of having all the mains current travel through the connector cable, finding a 120V controlled relay and run it in parrallel with the mains which would be switched by relay. The current traveling through the cable would just be the current needed to drive the relay. Are there such safe relays?
Old 7th November 2007, 05:21 PM   #13
Actually I forgot I have some of these...
120v relays
Old 7th November 2007, 05:26 PM   #14
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
I go to Industrial Electric Wire and Cable, http://www.iewc.com/
Last time I checked, the cable was in stock. Minimum order applies, but it wasn't all that much. You will definitely end up with more than 2 meters.
My suggestion on the shields is they are strictly used for shielding and grounding of the chasses, not used for audio signal conductors. Twisted pair plus shield should be all you require to keep each signal hot and cold in its own shield, happily isolated from the rest of the world. Circuit common, however you choose to implement, will use the cold conductor, not the shield. See http://www.nutshellhifi.com/Karna.gif for visual.
You never specifically stated if your tubes were direct heated or not, but if they are direct, keeping your filament transformers inside the amp proper makes for a shortest path or audio . Even if indirect heated, how small of a chassis are you planning that you can't avoid magnetic coupling to the output transformer? Push-pull or not, the issue doesn't change. Additionally, the more filaments you have to heat, the potentially more conductors you need in the umbilical; one 120VAC is all you need.
Old 7th November 2007, 09:35 PM   #15
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Originally posted by zigzagflux
Even if indirect heated, how small of a chassis are you planning that you can't avoid magnetic coupling to the output transformer? * * * Additionally, the more filaments you have to heat, the potentially more conductors you need in the umbilical; one 120VAC is all you need.
2 tubes (7788's) so current draw is under 1A, and while it isn't that small, it is a headphone amp, so any hum is way too much.
Old 8th November 2007, 12:33 PM   #16
NickC is offline NickC
kevinkr
Thanks for the link
I was wondering more about the connectors
Do you know how much voltage and current they can stand?
Nicholas
Old 8th November 2007, 08:06 PM   #17
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
If you have 12v in the PS, you can run a 12v loopback, to switch a normal 12v relay. safer than 120v...
I wouldn't bother, myself, but, perhaps if it was production use.
Optimal Umbilical Runs and ConnectionsHide this!Advertise here!
Looking for amp kit that runs on 12V (car battery) maurycy Chip Amps 5 2nd October 2008 08:29 PM
Dynaco ST-120 runs hot bobgroger Solid State 6 15th April 2008 05:20 AM
Neutrik XLR for Umbilical dsavitsk Tubes / Valves 14 17th August 2006 02:20 PM
Umbilical Supplies rtarbell Parts 1 9th March 2006 10:47 PM
BOSOZ's PSU runs very very hot ruangrit Pass Labs 18 5th February 2003 11:45 PM
