| diyAudio Sponsor | ||
For the longest time, I wanted to make an IT coupled amplifier. Why IT coupled? Because I haven't made one yet, and I like the simplicity.
The original goal was to use a WE404A/5847 pentode driver, IT coupled to a 300B. So, I'm hitting two birds in one stone here- the use of pentode as a driver, and IT coupling. I haveread J.C. Morrison's article in Sound Practices 14 and I was surprised to see that I actually have a pair of Raytheon 5847. So I thought of using these tubes for the driver. A long time ago, I had a pair of IT transformers made by my local winder. I never got to use them, and still sits here in my office. Since then, I have forgotten about IT-coupled projects. Then for the first time, I was able to make an IT-coupled PP EL34, driven by a paralleled 6SN7. It sounded very nice, but I never got to make beyond the breadboard. The IT is a Lundahl LL1660S/10mA that my friend started distributing here in the Philippines early this year. I asked Per Lundahl, if I can use the LL1660S in SE-SE mode instead of SE-PP. To my delight, he said yes, and I arrived at a modified ALT-T configuration. Here's the fruit of my labor over the last 4 days... ![]() By arnoldc ![]() By arnoldc At the last minute,at had a change of mind since I have NOT tested the 5847 ever, I swapped in a WE396A in parallel, instead. The rectifier is 5AR4 and FR107 in a Graetz bridge, through CLCLC, and there's a VR150 to regulate the driver supply going to the LL1660S. The power transformer is a Lundahl L1648, and the output transformers are James JS-6113HS. I'm operating the 300B within the output transformer current limit. Please do not ask me for the sonic virtues of the amp yet, as I haven't smoke tested it |
#2 |
ugly!
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Thank you, thank you!
#4 |
nice work prof!
#6 |
Nice! Do you have a schematic to share? Assume you don't have children, pets or careless adults around those trannys ![]() ck |
#7 |
Hi Ck,
I have the schematic in Visio but allow me to finalize everything, including voltage readings, to make it easier for anyboy interested. I do have a Shih Tzu who loves to nose around Incidentally, I just realized that the two Nichicon Muse electrolytics are in the wrong direction (polarity) |
#8 |
Finally, music!
Thanks to one of my mentor friend, who spent time with me tonight in troubleshooting the problem. We've covered all the usual suspects, checked and validated. Everything turned out right and I hav spent hours finding the problem. I was about to call it a night when I had this gutfeel to isolate a very unsuspecting component - the hum balance pot. While it gives me the proper resistance reading, it just don't work when power is applied. Geez! But that's over now. Because it's too late, I played female vocals only - Hayley Westenra and Patricia Barber. So far, I'm impressed. The vocals are simply gorgeous, the details marvelous. The best amp I've brewed thus far, and definitely a different league compared to all my capacitor-coupled designs. I haven't played any rock or heavy metal so far, but I like it very much already. Rock or no rock, my 300B tubes will no longer gather dust! |
#9 |
Well done.
Welcome to the IT revolution. What current did you decide to push through the drivers in the end. Is there any sign of high frequency roll off. Will you try it as PP, and how did the 300B SE compare to the EL34 PP amp. Lots of questions. Shoog |
#10 |
Hi Shoog,
Did you mean information technology? Geez, I was part of its evolution, spent 13 years with Unix from System 6 to AT&T System V R3. But now, I do Microsoft. Built my first Altair-style Intel 8008 chip based computer when I was young. My sonic description was based on what it is right now... Single section (should be paralleled) 396A, 150V B+ off the 0D3, LED on the cathode. My ears are not complaining about lack of top end sparkle, but I have to see it on the scope. There is no plan to make a PP 300B. Sonically, this SE 300B is a league above the PP EL34 with the same LL1660S. Cheers! |
| TCJ Cathode-Coupled Amplifier | seventenths | Tubes / Valves | 3 | 18th July 2007 05:05 PM |
| 417A-300B Plate Choke or Interstage Coupled? | sgerus | Tubes / Valves | 21 | 14th January 2007 12:45 AM |
| An intriguing 300B SE-direct-coupled-amplifier | Antonio Tucci | Tubes / Valves | 27 | 8th February 2006 09:34 AM |
| An intriguing 6S45P direct coupled 300B amplifier | Antonio Tucci | Tubes / Valves | 27 | 22nd October 2004 11:06 AM |
| Hoekstra DC-Coupled 300B ... oooooh! | serengetiplains | Tubes / Valves | 11 | 21st July 2004 03:33 PM |
| Page generated in 0.12494 seconds (83.17% PHP - 16.83% MySQL) with 11 queries |
