diyAudio Sponsor
Old 5th November 2007, 07:22 PM   #1
Default Ultralinear pse
Hi all
Surfing on the web I’ve found a schematic of an interesting pse amplifier. In the output stage there are three 6550 in UL. I’ve never seen before such a solution, so I’d like to know what you think about the connection of more than one screen grid to the same UL tap (43%).
Do you think it could produce any problem to the local feedback mechanism?
Mark
Old 5th November 2007, 10:54 PM   #2
Mark,
I don't see why it can't be made to work well. The 3 paralleled O/P tubes need to be very closely matched for gm and reasonably well matched for plate current. "Fixed" bias, with an individual adjustment for each tube, allows the idle current for each tube to be set, "perfectly". "Fixed" bias implies modestly sized grid leak resistors. So, low impedance driver circuitry is in order.
Eli D.
6GK6 Ultralinear jaymanaa Tubes / Valves 14 13th December 2007 12:03 AM
6V6 Ultralinear gingertube Tubes / Valves 12 4th May 2007 07:56 AM
Pentode vs Ultralinear alexmoose Tubes / Valves 9 13th November 2006 08:48 PM
PP-1c as Ultralinear Charles BL Tubes / Valves 1 28th January 2003 03:52 AM
Ultralinear vs SE Petman Tubes / Valves 46 10th January 2003 06:10 PM
Page generated in 0.06241 seconds (64.82% PHP - 35.18% MySQL) with 10 queries
