| diyAudio Sponsor | ||
Hi. I m reeealy interesting in making my first el84 tube amp in SE parallel configuration, and I would like to modify schematics of transciductance amp I have found on MagneQuest forum.OK , I know it is infected with SS devices ( those mosfets are in signal way) but the fact that amp would make fullrange driver go deeper in bass region is irresistible to me.So, can I just add 2 el84 more, and use 1/3 inn impedance OPT , or diferent biasing of mosfets is needed? Or how about diveloping Decware Zen with 3 el84? Maybe diferent input/driver tube is needed for extra current? And what tradeoffs should I expect with paralleling output tubes? Fullranger I had in mind is Audio Nirvana super 12 (incredible flat impedance , rising inbass region would work sinergesticaly with transcoductance amp, God bless N. Pass..., and high sensitivity... yammie). Help! Thanks
#2 |
You know the 9watts EL509 tube transconductance amp at the Magnequest forum?
I write in English worse than Tarzan |
#3 |
Here's a tested schematic for el84 parallel SE: http://www.diyparadiso.com/piccolo4.htm
tip: WE407a (20/40v heater) makes a cheap replacement for 2c51. Driver requirements are the same for parallel and single el84 (atleast voltage swing, input capacitance doubles but 'll hardly be problematic with el84). When redesigning a single el84 for parallel output you'll also have to adjust cathode resistor and bypass to maintain same operating point (use ohms law). For the opts I'ld aim for 2-5K Zout. Simon |
#4 |
Can somebody comment on why the amp in the original post is a *transconductance* amp? The output side looks like a traditional parafeed, so what's the big deal?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#5 |
You have information here >>>
http://db.audioasylum.com/cgi/m.mpl?...e+amp&session= Best regards Jaime
#6 | |
#7 |
Thanks guys, I ll try to actually do something now, I still cannot decide should I go for high power KT88 (or parallel el84) or "more purity" single el84 design."Maby" it is time to stop endlless reserch.
| ZV9 as transconductance amp | we416b | Pass Labs | 15 | 4th April 2006 09:52 AM |
| Transconductance. | lndm | Tubes / Valves | 16 | 18th March 2006 09:51 PM |
| seeking: tube for a SEP parallel feed like an EL84, but with a lower Ra | aletheian | Tubes / Valves | 30 | 17th November 2005 04:24 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Parallel PP EL84 and ouput transformer question | corbato | Tubes / Valves | 7 | 6th January 2003 01:26 PM |
| Page generated in 0.08507 seconds (78.14% PHP - 21.86% MySQL) with 11 queries |
