diyAudio Sponsor
Old 3rd November 2007, 10:29 PM   #1
Default Valve selection
Hi, I am requesting your expert help,
I am a newbie with a long interest in audio, I want to build a pair of mono block valve amps, I have aquired the following valves and I am looking for a suitable circuit diagram and BOM and if possible where these can be purchased.
I have these valves:
4x Telsa RD 200B
8x Tungsram RG 250/3000
thanks in advance,
Andrew...
Old 3rd November 2007, 11:25 PM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Andrew,
I split your post from the other thread. Since your question was not relevant to the thread you posted in.
Kind regards,
Bas
Ksa 200B ingemar Solid State 3 3rd April 2009 07:55 AM
For Sale: ECLL800 2 itt/lorenz 4 tungsram NOS Westerp Swap Meet 7 13th October 2007 10:54 PM
Counterpoint Sa-3000 Circuit Diagram NickBRN Tubes / Valves 3 2nd October 2006 02:54 AM
Tungsram tube data Diy martin Tubes / Valves 3 30th December 2004 11:59 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 09:49 PM
Page generated in 0.09384 seconds (62.83% PHP - 37.17% MySQL) with 10 queries
