Old 26th May 2011, 03:35 AM   #11
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Gee,I did'nt think that a high voltage microwave oven transformer could be used as a choke,missed this one because I stuck to theory that it must be gapped.Initially I thought I could salvage it for output duty when I found
most were welded along the E,I stampings that prevented one from disasembling to reuse the core.But since they are relatively big they could be used as power chokes to supply a decent current before they saturate or is it?
Old 26th May 2011, 07:34 AM   #12
Shoog's Avatar
I have used MOT's as power supply chokes and as plate chokes. There fine as both, though a proper plate choke is probably much better.
Shoog
Old 26th May 2011, 05:30 PM   #13
sheep is offline sheep  Canada
How about using a regular filiament transformer as a choke? Does the secondary need to be shorted?
CCS 10M45 in Cathode of CF Driver danFrank Tubes / Valves 13 5th March 2007 09:41 PM
10M45 Mu-Stage Idea? sgerus Tubes / Valves 44 1st March 2007 03:14 PM
IXYS 10M45 chip CCS Alastair E Tubes / Valves 3 31st December 2006 12:45 PM
Wanted IXYS 10M45 guglielmope Swap Meet 0 29th June 2006 08:10 AM
10M45 CCS, what am I doing wrong ? jj2 Tubes / Valves 7 16th April 2006 01:54 AM
Copyright ©1999-2013 diyAudio
