to DIY or not to DIY
Old 13th February 2003, 05:20 PM   #11
James D. is offline James D.  United Kingdom
Joel,
I've heard some nice vintage guitars but I have to agree that the last couple of years Fenders and Gibsons are as good as if not better than all the others... We're very lucky with present day guitar quality.
Maz,
I would recommend going with a good kit first and build it as standard and get used to it before modifying...
I fully agree with the comments about topology and operating points being 90% of the sound with tweaking being the final icing on the cake. I can hear a difference between component choice in most amps I've built - solid state or valve but it isn't always a repeatable difference
A good methodology with tweaks is to change one thing then live with it for a week or so - then reverse the change and see if it was really an improvement... this has been pretty fool proof for me...
ciao
James
Old 14th February 2003, 10:29 AM   #12
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
With output transformers being the number one tweak!
Generally speaking C-cores are a step up in detail...
to DIY or not to DIYHide this!Advertise here!
Resources saved on this page: MySQL 17.65%
Copyright ©1999-2017 diyAudio
