#11 |
Hi Ron,
What kind of tube do you plan to use? You have the current set to 25ma which doesn't sound right. Since you are looking at 12.6V heaters, you probably have something like 12SN7 or 12A?7 or series/parallel connect of 6.3 tubes such as 6CG7 or 6922. Just one of these tube will draw much more than 25ma, and you need to multiply that by 4!!! Try 4700uF - 2ohm - 4700uF to see you can get close to 12-12.6V.
- Fred - |
#12 |
Ron,
you're indeed way off with your heater schematic. Current draw for the heaters can be taken from the datasheets, but is usually in tenths of an ampere...like 0.3A or something. Filtering caps have to be much larger since you are dealing with lower voltages (for the heaters). So something along the lines in the pic attched should come closer...this is for two C3G tubes for my headamp, and actual values are very close! good luck!
#13 |
PCHW & STIXX,
Thank you both for your help and patience in teaching me! Now that you both have pointed out where I was wrong it is easy to see. Such is the beauty of hindsite. The Valve I will be using is ECC802s / 12au7. Heater currnet is 150mA @ 12.6V or 300mA @ 6.3V. My Transformer puts out 5A @6.3 so current suppply is not a problem. Modeling 150mA in PSUDII using STIXX schematic as a reference point (thank you) I compiled this circuit Note: I did not take voltage drop across the Bridge into account, I'll measure it later and adjust resistor values as needed. PSUDII is a little confusing because it states values of capacitors as mF------milli Farads, capacitor labels use the (m) to mean micro Farads. 18,000uF = 18mF in PSUDII, but looking to purchase a suitable capacitor 18mF = 18uF. This has confused me more than once. Question: Because the heater PS capacitor is floated with 1/4 B+ Voltage but referenced to itself @~12.6V, what is the recommended voltage range? 20V? (12.6V +10% for safety) or 80V? (1/4B+ (+) 12.6V + 10% for safety) I'm guessing 80V or 100V capacitor rating. Thanks guys! I really appreciate the help Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#14 | |||
Ron,
I'm no expert either but have modelled dozens in PSUDII and actually built two psu's with good results. Quote:
I'd grab two 22000uF/25V since you are still heating your tubes with 6.3V and not 60V or something. I can't put the explanation in scientific terms (at a lack of words here being german ) but referencing the heaters to B+ of course doesn't change heater voltage.best, Oliver |
#15 |
Stixx,
Sehr Dank, My German is not good, sorry. But Thank, Thank, Thank you. In PSUDII the (m) for size of capacitors is milli, not Mega. see below, I am having enough trouble understanding what I am doing without adding a rectifier valve too. Obviously this is my first Preamp - electronics project. Ich möchte ein Bier trinken mit Ihnen (from Google translate) Ron
#16 |
Hi Ron,
You mentioned that your trafo has 2 x 6.3V secondaries. So, the 5A rating is the sum of the 2, correct? Or, it is 5A each Either case, you will need to wire them in series to get 12.6V, so the current rating will be the same. 4 x 12AU7 in 12.6V only consume 0.6A total, you have plenty to spare. If you want reasonably good heater supply, use a LM317T to regulate the voltage, 0.6A is well below it's 1.5A limit. You will find plenty references here or in the web on how to use LM317T. If you don't want to get too complex for the time being, just use CRC where C=4700uF (as Oliver said, 25V rating is good enough) and R=3 or 4 ohms (5W). Later, you can upgrade the RC section to the LM317T circuitry. For 12AU7, connect the ground of the heater supply to 1/4 of the B+ should be good.
- Fred - |
#17 | |||
I learned from reading, and more reading...Quote:
Oliver |
#18 |
I must be learning!!!!
I let the magic smoke out of the Bridge rectifier yesterday I looked at the transformer and it is (1) 6.3V CT...not (2) 6.3V secondaries... .....I must be learning......SOMETHING.....??After I finished laughing, I figured out what I did and DOH! Newbie me, I twisted both legs of the CT 6.3 to the + of the bridge and ran the CT to the - side......and POOF! Pretty blue smoke , blew the fuse too! LOL .....I must be learning.Oliver, Prost! Thanks for the words of encouragement! I realize that my transformer has 6.3V CT, so unless I use a voltage doubler circuit I will have to use 6.3V for Heater Supply. I know A/C is OK, but I'd prefer DC heaters. Fred, Thanks for the suggestions with the LM317T, I'll go with that after the FW rectifier with CT. Thanks Very much guys! Ron
#19 | |
No guts, no glory, right When you twisted the two legs of the 6.3, you effectively shorted the secondary. Good that you had the fuse in place. Before you work on the doubler, measure the AC of the 2 legs just to make sure it is 6.3. Also, tape the CT to void accidentally shorting. You are not likely to use it. Have fun!!
- Fred - |
| Eagle vs. Sprint-Layout for PCB design/layout | hollowman | Parts | 10 | 8th October 2012 06:13 PM |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| aikido hybrid with 5 A bias | oliezt | Tubes / Valves | 2 | 30th July 2007 02:54 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 10:24 AM |
