#21 |
OK, a newbee question for Tube master: I like your new schematics, but somthing about pentode mode - What about rising pentode response in high frequences range, since there is no NF of some sort...And what electolitics do you racomend? How this amp compares with your dirrectcoupled el84 design,soundwise? Thanks
#22 |
Rising response in a pentode driver stage shouldn't be an issue. This is because it is working into a purely resistive load (the RC network of the driven tube).
The reason you get a rising response in an ouput stage is because of the high rp of the pentode in relation to the falling reactance of the output transformer. My understanding is that pentodes make excellent driver stages. I will be using pentode drivers in my next power amp. Shoog |
#23 |
Thanks Shoog, my question was about output pentode, but answer lies in that 2K resistor before output primary,wright?
#24 |
The 2K resistor is simply there to prevent excessive screen current on signal peaks, it will have no effect on the rising response.
I personally think that the pentode mode of this implementation will exhibit a rising response. I would implement a plate to plate feedback arrangement to tame this, and this could easily be switchable in and out using a two gang switch for the pentode mode and feedback (search on RH84 if you are interested) If you were doing this I would make the driver EL84 pentode (possible switchable again). Shoog |
#25 |
This beginers darkest fears come true!
#26 | |
#27 |
Hi Nasha,
I have the same thought about a good wide range + tweeter combo. but did not have the skill to design a suitable x-over... Did consider an active x-over + bi-ampi for that. BUT that stayed as a plan still. Have you any action plan for that? Cheers
Audio_Idiot |
#28 | |
Try looking at this link for a respected designers opinion on the use of a pentode driver. http://www.pmillett.com/813_se_triode_amps.htm My intended application is in a lose clone of Gary Pimms Tabor amp. Here a 6AU6 is used with plate to plate feedback to the output pentode. The high output impedance of the driver is just what is needed in this application. So take your choice, believe a general audiophile myth or take the word of two excellent electrical engineers. I know what I will choose to believe. Every device and every circuit has an applicable application in the hands of an intelligent designer. Shoog |
#29 |
Hi Audio Idiot, I would keep it simple, like just cap on tweeter and fullrange without any crossover, or find an old equilizer and try it in front of powerful amp in biamped configuration.I consider open baffle with Audio Nirvana super 10 fullrange, and Eminence alfa 15 for bass. AN s 10 without any crossover (open baffle provides natural rollof - hi pass) and would be driven by Decware Zen or Tube Master design el84 or transconductance el84 . In my dream system 15" woofer would be powered by F1 ( by Nelson Pass) , a transconductance amp to inject more power in that rising impedance of the bass driver - kind of equalization by itself. I don t know if it is agood idea but Ill try...
#30 | |
Hi Nesha, you are quite right. The behaviour of the circuit depends a bit on the output transformer. The result in pentode mode is not always linear on the scope but still can be very pleasing. I don't recommend any specific electrolytics, use what feels good to you. It gives each amp an individual note since component choice can be heard in such amps. The coupling cap can be a nice type. That's why it's hard to compare the amps soundwise, but they do have something in common... Best regards Michael |
| Pse El84 | vizion | Tubes / Valves | 3 | 16th October 2007 04:36 PM |
| EL84 to 6l6 | karma | Tubes / Valves | 8 | 18th June 2005 11:05 PM |
| el84 amp | mark_titano | Tubes / Valves | 86 | 21st April 2005 04:14 PM |
| el84 help | inquisitive | Tubes / Valves | 14 | 26th March 2005 07:19 AM |
| SE el84 | takashi | Tubes / Valves | 10 | 29th June 2004 01:34 PM |
