| diyAudio Sponsor | ||
Hi Folks !
I googled several times and couldn't find an answer. The Hammond Mains Transformers do all have a center tap, like "260-0-260". Is it possible to remove the endbells and to split the two windings ? I need two seperate Volatge sources for a circlotron. Of course, if the connection between the two windings is inside the packing, this is not possible. but maybe the wires are connected outside the windigs. This is what I would like to know. Maybe someone of you has some experience with that ;-) Best regards, Simon
Терпенье и труд все перетрут
| Hammond 269 EX transformer (never used) | zenmh | Swap Meet | 7 | 4th August 2009 07:06 PM |
| HT Sealed Mains with Vented Center? | diesel_88 | Multi-Way | 4 | 8th July 2008 09:59 PM |
| Shielded center/mains projects. Any suggestions? | manxam | Multi-Way | 1 | 5th January 2004 02:49 AM |
| Is there any easy way to design a center channel that will match my Polk mains? | mikejz84 | Multi-Way | 6 | 18th July 2003 12:03 AM |
| Page generated in 0.05558 seconds (66.56% PHP - 33.44% MySQL) with 10 queries |
