diyAudio Sponsor
Old 26th October 2007, 03:05 PM   #1
DRC_YUN is offline DRC_YUN  Thailand
Default 6SN7 with transformer coupling
Hi, I wanna make pre-amp using 6SN7 with transformer coupling. please anyone suggest the opt to use with my project and suggest the spec of the opt to use. Or anyone who has built or listened to this kind of pre-amp could tell me about the sound of this pre-amp.
Thank you very much for the answer.
Old 26th October 2007, 03:43 PM   #2
robertc is offline robertc  Malaysia
try this http://www.sacthailand.com
Transformer Coupling Questions audio_moksha Tubes / Valves 6 15th January 2008 08:14 PM
Frrank's 6Sn7 preamp...take out coupling cap?? charliet Tubes / Valves 5 3rd December 2006 01:39 PM
Transformer coupling and output for SS mashaffer Solid State 1 17th May 2005 07:47 AM
SE 6SN7/813 direct coupling QuarkStrange Tubes / Valves 5 4th April 2005 11:00 AM
Transformer coupled 6SN7 push-pull DAC output stage? cathode_leak Tubes / Valves 7 24th January 2005 07:26 PM
Page generated in 0.06976 seconds (71.67% PHP - 28.33% MySQL) with 10 queries
