feedbackless interstage p-p kt88 amp
Old 26th October 2007, 02:30 AM   #1
robertc is offline robertc  Malaysia
Default feedbackless interstage p-p kt88 amp
can someone comment this high cost diy amp. with tango interstage and tamura opt. heard that this is the best push pull power amp.
Old 26th October 2007, 06:19 AM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Default Re: feedbackless interstage p-p kt88 amp
So far as this being "the best", I suppose that's a matter of preference. However, feedbackless it ain't. You have an ultralinear connection and feedback to the cathodes off the OPT. That's a lot of feedback. Click the image to open in full size.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 26th October 2007, 07:25 AM   #3
yes, miles. you're right, there was a cfb.
Anyone know where i can buy the tango nc14 online?
Old 26th October 2007, 08:06 AM   #4
AndreasS is offline AndreasS  Germany
hello,
the Tango NC-14 is for a current of 15 mA, ...
Sources: http://www.eifl.co.jp/index/export/ISO.html
Regards Andreas
Old 26th October 2007, 11:46 AM   #5
Shoog is offline Shoog
Shoog's Avatar
The primaries are in parallel so the transformer should be good for 30mA or the required 26mA.
I would guess that this should be an excellent sounding amp.
Shoog
Old 26th October 2007, 12:11 PM   #6
andyjevans is offline andyjevans  United Kingdom
I can only imagine the amp would sound better still with 2E22 in the outputs!!
Old 26th October 2007, 12:30 PM   #7
whether this thailand made (I-311P) interstage better then tango nc14?
I-311P 3.0K 3.0K 1+1 : 1+1 15-80,000Hz 60 47 180 2A3, EL84(T), EL34(T)
http://www.sacthailand.com./
Look at the test result.
I got a pair tamura in hand and just need the interstage to build this amp.
Old 26th October 2007, 02:29 PM   #8
resident is offline resident
Account Disabled
I thing it's better to use a SE interstage...
By the way, I wouldn't trust a company that measures the impedance of their products with a digi-bridge!
Old 26th October 2007, 02:56 PM   #9
richwalters is offline richwalters
richwalters's Avatar
I've never been entirely convinced that anyone can repeatedly make perfectly balanced p-p interstage transformers which in this case has to be to avoid thd at the higher frequencies. If it is so easy to make them, then it would be the obvious to use'em. Not quite so. Miller effect rules KT88's and not two are sim.
Where is the final amp performance spec (If I've missed it) ?
richj
Old 26th October 2007, 03:40 PM   #10
look like i go for tango nc14. i 'll report the result when everything done.
feedbackless interstage p-p kt88 ampHide this!Advertise here!
45 -> 813 Interstage Steven-H Tubes / Valves 34 3rd February 2008 04:39 PM
help with interstage needed schiller Tubes / Valves 0 17th April 2006 07:42 AM
help with interstage tranny with SS? AudioGeek Solid State 7 14th March 2006 01:13 PM
4K:10K interstage astouffer Tubes / Valves 0 24th March 2005 04:34 PM
Copyright ©1999-2017 diyAudio
