diyAudio Sponsor
Old 25th October 2007, 05:36 AM   #1
sorenj07's Avatar
Default 6P9/6AG7 Triode Amplifier
It's a budget model but I hope to get some good sound. Wish me luck
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 26th October 2007, 05:15 AM   #2
sorenj07's Avatar
Bit of a mistake - replace those two full wave rectifiers at the top with diode bridges, it's a plain 230V secondary.
Old 26th October 2007, 12:12 PM   #3
ilimzn is offline ilimzn  Croatia
There have been several threads about including a diode in the plate-G2 connection, with most experienced designers agreeing it will definitely not make things better, and may in fact make things considerably worse (as in burnt G2).
Old 26th October 2007, 01:50 PM   #4
sorenj07's Avatar
I basically lifted that part straight from Poindexter's Musical Machine. I assume that if it hasn't burnt his screens, it probably won't burn mine, as long as the diode is pointing the right way
6AG7 Amplifier sorenj07 Tubes / Valves 12 4th June 2011 02:32 PM
Triode Dick/FdeGrove 2A3 PP amplifier grimberg Tubes / Valves 24 10th March 2010 05:24 AM
2a3 Triode Guitar Amplifier 2a3geek Instruments and Amps 2 23rd November 2008 07:34 PM
6AG7 UL Curves sorenj07 Tubes / Valves 6 16th October 2007 05:17 AM
6ag7 metal pentodes martinab2 Tubes / Valves 4 8th October 2007 07:30 AM
Page generated in 0.09157 seconds (66.56% PHP - 33.44% MySQL) with 10 queries
