diyAudio Sponsor
Old 24th October 2007, 11:11 AM   #1
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Default Rogers Cadet III Advice & Opinions Needed
I am a complete noob to tubes. After listening to a friends valve amp I am looking to buy/build one for myself.
I have been offered a Rogers Cadet III, it seems to be a one-box integrated version? The chap is asking £165 including all the valves, this isn't working, he says it powers up but just hums through the speakers. I suspect this could be bad caps, but I know of a guy who could fix it cheaply.
The other amp is a fully working pre-power version for £230.
I would really appreciate some advice here. Are they worth these prices? Could I build something better for not much more?
Please help!
Lee.
Old 24th October 2007, 01:05 PM   #2
316a is offline 316a  England
316a's Avatar
Default Re: Rogers Cadet III Advice & Opinions Needed
Please help!
Lee.
The power amps seem to be very overpriced , these typically go for £60-100 . The Cadet 3 is not a particularly inspiring power amp , the output transformers are rather small . The pre-amps use the unobtainium ECC807 (£45 each new) and are not really of much use apart from the phono stage . I bought my Cadet 3 pre and power for £30 , it took a complete rebuild as all the caps were shot and most of the resistors had drifted . The pre-amp went on Ebay . The ECL86 tested all over the place , two of the originals were retained and another two were matched up from stock . Mullards are becoming more hard to find these days . A good entry to DIY if the price is right . Don't expect miracles , this is a 'budget' amp
cheers
316a
Old 24th October 2007, 01:34 PM   #3
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Please help!
Lee.
Lee,
I have had a couple of the integrated versions. In my opinion, they are an excellent first tube amp. I was driving Spendor SA1s (inefficient) and it was a little underpowered to go really loud but nice at normal levels.
However, at that price, I would say too much especially as it is not working. He is probably looking at the price of the ecc807's on Ebay and going from there.
The preamp section is not much cop. There have been a couple of threads where these have been rebuilt into 'baby hueys'.
Look on Ebay. They come up fairly frequently or haggle hard.
http://cgi.ebay.co.uk/rogers-cadet-3...QQcmdZViewItem
http://cgi.ebay.co.uk/STUNNING-Roger...QQcmdZViewItem
Andy
Old 24th October 2007, 07:51 PM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
£165 is a lot for a non-working Cadet III. Five years ago, I paid £80 for an alleged working integrated Cadet III. Every single electrolytic needed to be replaced. That said, the Cadet II is quite a nice little first valve amplifier. As has been previously said, the output transformers are rather small.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 25th October 2007, 07:14 AM   #5
Thomo's Avatar
Thanks for your opinions guys. That link for the non-working one on ebay has no valves with it. I guess buying replacement valves would be expensive.
I think I'll hang on and find a better value alternative.
My speakers are Tannoy dual concentric, >100db sensitivity so power is not top of the list. I am just after an amp that would better suit these. Do you get much detail out these rogers amps? I am currently running a modified/rebuilt Quad405.
Lee.
Suggestions needed for improving Rogers Cadet II PP power amplifier Sanjiv Sahgal Tubes / Valves 10 23rd May 2012 09:26 AM
Rogers Cadet III Schematics needlesview Tubes / Valves 23 14th September 2007 08:50 AM
Rogers Cadet III schematics Corrections jkeny Tubes / Valves 4 21st January 2007 08:23 PM
Rogers Cadet III PU Adapter Jon Bradbury Tubes / Valves 16 19th January 2007 03:45 PM
rogers cadet mk3 hummm..... boxenergy Tubes / Valves 1 21st April 2005 11:30 PM
Page generated in 0.10320 seconds (73.59% PHP - 26.41% MySQL) with 10 queries
