diyAudio Sponsor
Old 24th October 2007, 12:50 AM   #1
240z4u is offline 240z4u  United States
Send a message via AIM to 240z4u
Default CCS for 12B4 linestage
Would this be adequate for a CCS for my 12b4 line stage?
I need to build two correct?
http://home.pacifier.com/~gpimm/self_bias.htm
Thanks alot guys!
Evan
Yeah... it seemed like a good idea at the time.
Old 24th October 2007, 12:58 AM   #2
hey-Hey!!!,
You'll need one per 12B4. Suggest using the 'mu' output. The DN2540 cascode is a lot simpler... Try it with DN3545N3 on the bottom, and a 2540N5 on top to dissipate the heat.
cheers,
Douglas
the Tnuctipun will return
Old 24th October 2007, 01:47 AM   #3
I looked for the DN2540 stuff that you emailed me about. I could not find it.
Do you have a specific schematic? Easier would be better since this is my first scratch build!
Thanks buddy!
Evan
Old 24th October 2007, 11:51 AM   #4
euro21 is offline euro21  Hungary
Default 12B4A+CCS
Try C4S.
Old 24th October 2007, 01:01 PM   #5
Thanks guys!
Evan
Old 24th October 2007, 06:44 PM   #6
Account Disabled
thanks euro21!
I think I'll add this, to my 12B4A preamp!
I have built it a long time ago and I have never changed the anode // resistors
Old 24th October 2007, 06:51 PM   #7
MikeR is offline MikeR  United States
Default Another CCS 12B4
Here's another take on a 12B4 with CCS. This is not my work and I apologize to the author for forgetting its origin. Looks interesting.
Old 24th October 2007, 06:53 PM   #8
Default And Another one
A completely different type of CCS for 12B4 linestage. Again, not my work and I have not tried it.
Old 24th October 2007, 10:11 PM   #9
hey-Hey!!!,
With the BJT transistors, getting a mu output is not possible. Since regulated current will get split between cathode and output signal, it might be best to use a bypass capacitor on the cathode resistor. Of course, one could switch between plate output and mu output....I suspect that there will be one that works better given the rest of the system...
cheers,
Douglas
12b4 vs. aikido linestage Klimon Tubes / Valves 2 14th August 2007 11:38 AM
12B4-A Linestage sorenj07 Tubes / Valves 51 12th February 2007 02:29 AM
low frequency oscillation in 12B4 linestage Original Burnedfingers Tubes / Valves 8 11th December 2005 12:27 AM
12B4 versus 6S4 for linestage rcavictim Tubes / Valves 4 4th December 2005 08:22 AM
12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) DougL Tubes / Valves 3 2nd August 2004 06:06 PM
Page generated in 0.09608 seconds (69.60% PHP - 30.40% MySQL) with 11 queries
