diyAudio Sponsor
Old 23rd October 2007, 01:46 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default look for schematic of 12v preamp ???
i am look for a 12v preamp or amp that run s on 500ma or less
hers a useful tube site that run at this lower voltages
http://www.duntemann.com/12vtubes/12vtubesindex.htm
Old 23rd October 2007, 05:27 PM   #2
Alastair E's Avatar
Check out this-
http://www.diyaudio.com/forums/attac...amp=1172352853
The thread it comes from is here...
6SL7 or 6SL7GT for broken Tubalizer
The thread Ive listed goes for several pages. The Tubaliser is discussed as well as the scheme I came up as an alternative...
I have used this scheme and am currently using it with the 7586 Nuvistors or the 6C51H-B Russian Equivalent. Works well....
Das Beste Oder Nichts
Old 25th October 2007, 07:33 PM   #3
unclejed613's Avatar
prorms, check out the thread you started about the distortion you were getting on your preamp model. i posted a schematic there for you. even though it says 12AU7, i'm actually using submini 6BF7 dual triodes, which actually have a little bit more gain than a 12AU7. the 6BF7 filaments are wired in series, and draw 200mA, and the preamp itself uses a little more than 1mA. total gain of the circuit is 15 to 20 with only .2% distortion at signal levels below 0.2V. you could do the same with a pair of 12AU7's, but your filaments will draw a bit more current.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Looking for schematic of 26 WOT Preamp lanew Tubes / Valves 4 8th April 2009 04:40 AM
Need help to check out this preamp schematic. pchw Tubes / Valves 7 27th December 2007 07:47 PM
Looking for Schematic using KC3 Preamp ? calico88 Tubes / Valves 0 3rd July 2006 04:00 AM
Preamp schematic. beppe61 Solid State 47 16th March 2005 07:24 AM
Preamp schematic... Guiness Tubes / Valves 17 12th February 2004 02:37 PM
Page generated in 0.07060 seconds (73.06% PHP - 26.94% MySQL) with 10 queries
