diyAudio Sponsor
Old 23rd May 2010, 11:18 AM   #11
trondareo's Avatar
Following mashaffers question. Would you implement the colors in such a way that the wire´s function, i.e. what equipment they were providing signal or power for, determined the wire´s color?
Seems logical.
Old 23rd May 2010, 06:23 PM   #12
I have got this info:
EIA RETMA Chassis Wiring Color Code
In the 1950's the Radio Electronics Television Manufacturers Association (RETMA), now part of the Electronics
Industries Alliance (EIA), used color codes to identify electronic parts, such as capacitors and resistors. In addition,
there is a lessor-known EIA equipment Wiring Code that identifies the type of circuit each wire serves.
Color - Circuit
Black - Grounds, grounded elements and returns
Brown - Heaters or filaments, off ground
Red - Power Supply B-plus
Orange - Screen grids
Yellow - Cathodes
Green - Control Grids
Blue - Plates
Violet - not used
Gray - AC power lines
White - Above or below ground returns, AVC, etc.
Most electronic manufactures of that era, including the popular Heathkit , used this color code for chassis wiring.
When working on antique electronic equipment of that era, this color code can identify circuit wire functions
without a schematic or wiring diagram.
Reference verification: Popular Electronics Magazine 1958 July, page 78
Old 29th May 2010, 12:30 AM   #13
wa2ise is offline wa2ise  United States
wa2ise's Avatar
Originally Posted by Jeb-D. View Post
When green is used for safety ground, what color is to be used for the control grid?
Green. The power cord is likely to not be near grid circuits (you don't want a whopping big 120VAC source of hum close to a grid circuit!), so there won't be much confusion. But often inside audio amps the grid circuits are comprised of resistor leads to ground, and capacitor leads to the previous stage's plate. Thus no hookup wire involved. As driver tubes are usually mounted near their output tubes.
Often in consumer electronics of the day, they used whatever color wire they could get cheap, so don't get puzzled when the wiring colors don't make sense.
Oh, and violet wire codes to negative power supplies, like a bias supply for the output tubes.
Old 29th May 2010, 12:42 AM   #14
nigelwright7557's Avatar
Originally Posted by gingertube View Post
I a
For the possible benefit of others I posted the link. It does make set to work and fault finding easier.
Ian
When I was being taught electronics they made us just use one colour of wire to make things as difficult as possible.
Wiring 25 way connectors to each other was great fun !
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Problem witht [code]blah[/code] ? elseif Forum Problems 1 17th August 2008 12:30 AM
Color Code Rodeodave Everything Else 3 22nd July 2008 12:40 PM
Quicksilver M135 Output Transformers Color Code? dshortt9 Tubes / Valves 2 13th October 2006 09:52 PM
Need wiring color chart info ? Keypad2k2 Car Audio 3 15th September 2005 09:18 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Page generated in 0.07827 seconds (82.12% PHP - 17.88% MySQL) with 10 queries
