diyAudio Sponsor
Old 22nd October 2007, 08:55 PM   #1
sorenj07's Avatar
Default Cathode Feedback How-To?
I link to this image in a recent thread. I'd like to try and implement cathode feeback in a modest pair of Hammond output transformers I purchased from eBay.
Schematic:
The thing is, I don't have the faintest clue how to work these extra windings. Is there a certain web page or book that might help? I just have Morgan Jones' Valve Amplifiers and will give it a look pronto. Should I just go with the DCR's of each winding and add any extra resistance I need in order to bias the tubes? Should I wire the CFB windings criss-crossed between tubes? I'm not even sure I can figure out which way is which with the wires, anyway...
Thanks for any help.
Old 23rd October 2007, 12:44 AM   #2
So, you finally noticed the tertiary winding. Good!
Your diagram tells you how to connect things up. Use A1 on the plate of 1 tube and K1 on the cathode of that tube. Wire the 2nd tube to A2 and K2. Combination bias is (IMO) the way to go. Use a 100 Ohm resistor in parallel with 330 muF. between the CT (black) of the tertiary winding and ground. A negative supply with 1 idle current set pot./channel allows experimentation with the operating point.
The connection of the tertiary winding to the cathodes provides local NFB. It's an excellent way of improving both linearity and damping factor in pentode mode "finals". Of course, TANSTAAFL applies and a higher drive voltage is necessary. A few dB. of loop NFB will polish things off nicely.
6V6 family "finals" with the screen grid B+ provided by a VR150 seem OK. For starters, set the idle current at 35 mA./tube and the plate to cathode differential at 300 V. You must protect the O/P trafo cores from saturation by rolling infrasonic garbage off at the amp's I/Ps. That 15 W. "iron" is going to be pushed to its limits.
Eli D.
Old 23rd October 2007, 01:54 AM   #3
KSTR is offline KSTR  Germany
KSTR's Avatar
http://www.plitron.com/PDF/Atcl_4.pdf
Old 23rd October 2007, 03:25 AM   #4
Dave Cigna's Avatar
Default Re: Cathode Feedback How-To?
http://captain-foldback.com/Hammond_...R40_QR40_1.gif
January 20, 2009: Bush's last day
Old 23rd October 2007, 06:04 AM   #5
sorenj07's Avatar
thanks for all the info
Cathode Feedback from Secondary for PP Amp gingertube Tubes / Valves 22 2nd July 2009 12:45 AM
Cathode feedback on SimpleSE nvrgdenuf Tubelab 5 13th March 2009 02:43 AM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
A thought on Cathode feedback alexmoose Tubes / Valves 12 15th April 2007 05:15 PM
Cathode feedback mark_titano Tubes / Valves 20 11th August 2005 02:56 AM
Page generated in 0.08559 seconds (73.98% PHP - 26.02% MySQL) with 10 queries
