diyAudio Sponsor
Old 22nd October 2007, 07:39 PM   #1
Svein_B is offline Svein_B  Norway
Default How much feedback for PP penthode?
I have rebuilt an EL84 PP amp.
The OPT has no UL taps so I am stuck with straight penthode operation.
I am wondering how much global feedback is generally considered good practice.
Before my rebuild it had a GFB of around 7dB which gave an output impedance of 5 ohm which I think is a little high.
I have increased the GFB to a little over 9dB and get 4.2 ohm output impedance. Does this sound reasonable?
I tried triode operation also. This gave me 5 ohm with no GFB, and 3 ohm with 7dB of GFB - but only around 3W power at 250V.
SveinB.
Old 22nd October 2007, 09:30 PM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
It's usually necessary to use about 26dB. For so much NFB, you need lots of open loop gain and the challenge is to maintain a good margin of stability. The necessary feeback ratio does depend on your speakers, though, and you may find you can get good results with less NFB.
Old 23rd October 2007, 04:22 AM   #3
frugal-phile(tm)
planet10's Avatar
Are the screens regulated?
It would be interesting to try the Yves/Gingertube scheme for feedback,
That said, our EL84 PP is stuck in triode and sounds so good we don't want to muck with it.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd October 2007, 05:22 AM   #4
Miles Prower's Avatar
Default Re: How much feedback for PP penthode?
There isn't any. It all depends on what pentode you're using, how well the open loop is implemented, what speeks you're using, what your preference in sound is.
I did two PP pentode designs. One of these uses 807s. For this particular design, there was 6.95db(v) of local feedback from the 807 plates to the driver, and about 4db(v) of gNFB around the entire amp, including the OPT.
Another design uses the 6BQ6GTB HD PA, also PP pentode since this type, like the 807, has a very low Vsgsg rating that makes either trioding or Ultralinear impractical. 6BQ6s are different, in that there wasn't the same sort of pentode nastiness when running open loop, so I decided to skip the local feedback. For this design, I made the gNFB adjustable, from none at all to 12db(v). For hard driving rock (Ozzy, Nirvana, Foo Fighters) and techno, 6db(v) sounds right. Softer music (Karen Carpenter, Andre Rieu) the full 12db(v) works better, but makes the harder rock sound a bit "subdued".
Too little gNFB makes for some sloppy-sounding bass due to woofer underdamping.
"It's usually necessary to use about 26dB."
No well designed VT amp should ever require anywhere near that much gNFB. That will lead to a very "solid statey" sound Click the image to open in full size. If you find that it's necessary, then you need to rethink your open loop design because you did something very wrong. Either that, or your speeks are no good.
Finally, if you're going full pentode mode, good screen regulation is mandatory. I use active voltage regulation to supply screen voltage.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd October 2007, 01:53 PM   #5
Thanks for the guidance.
It seems that my increase to 9dB of global feedback is still fairly low according to general wisdom. With existing tubes this is about as much as I can do and still have enough gain. The next re-wiring will be to try a variant of the Yves/Gingertube partial feedback scheme, and different driver tubes.
Please allow me to apologize for my spelling mistake in the thread title.
The correct spelling for the tube discussed should be pentode.
. . unless of course we should happen to use a beam tetrode.
SveinB.
Old 23rd October 2007, 05:18 PM   #6
Not really. Originally, it was spelled "penthode". The 'h' was dropped later.
www.dolphin-hsl.com
Old 23rd October 2007, 05:23 PM   #7
richwalters's Avatar
Default Re: Re: How much feedback for PP penthode?
Originally posted by Miles Prower
There isn't any.
I'd copy what Miles says. Only to add that a well sounding reflex of B4 alignment (traditional) needs no more and will sound quite loose. That's the beauty of tastes. I use 20dB global nfb in UL p-p. Anymore sounds clinical. Despite classical users often saying wanting more nfbfor exactness, I dispute this. As being a player I like to hear some cello and lower end piano resonance. On the other hand, on stage I blow trumpet and use a multiple 807 amp in true p-p and low nfb to get a rasp. Two distinct different usages both with excellent results.
Some MI tube amps often used in HiFi reinforcement often without the listeners aware of it ! and better still prefer the sound !
richj
Old 24th October 2007, 12:53 AM   #8
ray_moth's Avatar
I disagree, 26dB is not a lot for pentode-mode. Many of the 'classic' UL PP amps of the fifties and sixties had that much NFB, if not more, and they shouldn't have needed so much being UL. Don't forget, we're talking about pentode mode here. You have to cope with much higher OP impedance with pentode than with UL or triode. e.g. plate impedance of EL34 is about 1k in triode, 2-3k in UL but 15k in pentode mode!
You need to regulate the screen and to apply a healthy dose of NFB, with pentodes, to give decent damping with almost any speaker and to tame the higher-order odd harmonics distortion that pentodes tend to generate. Of course, it goes withopuit saying that NFB should be as low as possible but no lower.
Old 24th October 2007, 02:04 AM   #9
Yes, and all those "classic" designs sounded just like what they were: typical "Big Box" designs. Click the image to open in full size. Using s-loads of gNFB to force impressive THD numbers gives the marketing department something to brag about, but what good does it do to say you have an amp with a THD of 0.00000000000000000000000000000001% if it sounds horrible? When I was doing the design for the 807 amp project, I originally had it set up for some 30db(v) of gNFB, just like conventional "wisdom" says. That lasted all of 30 seconds as it sounded even worse than the solid state amp I was using at the time. And, yeah, even worse than running open loop with no NFB connected at all. I'd take the sloppy bass and even the pentode nastiness over that any day of the week. Next, I dropped that to 12 db(v) and it wasn't much better.
Would you throw a heavy wool comforter over your speeks and listen through that? Nah, me neither, but too much gNFB is the electronic equivalent: the highs were completely gone, bass sounded like monotonic thumping, vocals faded into a bland background, and lyrics became noticeably harder to understand, and fine details were lost. Just like that SS amp that got such good reviews at the time, and which I "thought" sounded pretty good. It turned out that some 4.0db(v) of gNFB was about right for that design. Sounds just fine: bass has plenty of "authority" without sloppiness, and the pentode nasties are gone. Playing familiar material through it was quite a revelation as there was so much detail that I literally never heard before.
The current project uses PP 6BQ6s running as pentodes (since the low Vsgsg rating pretty much eliminates the trioding and UL options) with adjustable gNFB from none at all to 12db(v). The full 12db(v) is definitely tending towards a "solid statey" sound, but does work well with some material. For metal and techno, 6db(v) is better.
Tell me something I don't already know.
You need to regulate the screen...
Dunnit
...and to apply a healthy dose of NFB, with pentodes, to give decent damping with almost any speaker and to tame the higher-order odd harmonics distortion that pentodes tend to generate. Of course, it goes without saying that NFB should be as low as possible but no lower.
Yes, gNFB should be as low as possible, and I still say 26db(v) is too damned much. In the final analysis, hearing is believing.
www.dolphin-hsl.com
Old 24th October 2007, 04:44 AM   #10
ray_moth's Avatar
Hi Miles,
Actually, not all of those old designs sounded bad. The Cit II used a lot (30dB?) of NFB but didn't sound too bad. Maybe today's speakers call for something else, though?
This wasn't intended for your benefit especially (since it's plain from your earlier posts that you already know it) but was aimed at the Forum at large.
You make a compelling case for low NFB. No one would be happier than I to achieve acceptable performance from pentodes with, say, 12dB or even less. If the speakers are up to it, with reasonably linear pentodes (or beam tetrodes, of course), then why not?
I think the thing is do design for stability at 26dB of NFB, then if it turns out that this much is unnecessary all well and good - reduce NFB to suit your needs. It's better to have it available and not need it than the other way around.
How to change this design from penthode to triode or UL wrangler Tubes / Valves 8 2nd November 2006 02:51 PM
6l6 penthode triode vlljpior Tubes / Valves 1 28th October 2006 08:53 PM
EF86 penthode specter73 Tubes / Valves 8 7th December 2005 05:38 PM
47 Penthode in triode mode. Diy martin Tubes / Valves 6 24th September 2005 01:16 AM
Page generated in 0.13413 seconds (84.60% PHP - 15.40% MySQL) with 10 queries
